Offroad & 4x4
In a bind on 9" gears (double post)
Old Mar 23, 2005 | 10:01 PM
hoxiii's Avatar
hoxiii
Allright, I posted this in the axle forum, but am in a bit of a bind so I'm tossing it out here, too.
9" differential gears:
I know you can ID the ratio by looking at the stamping on the side of the ring gear. However, it's been over a year since I've handled a set, so I have a question. Is the ratio stamped directly into the ring gear, or is it like dana axles where they stamp in the number of teeth on the ring gear and on the pinion and you have to figure it out for yourself? If it is like dana axles, what combo am I looking for for 4.11's?
I really need a set and know a guy with ALOT of third members hanging around, I don't want to make him go through every set counting teeth and running division, so it'd be nice if i could tell him exactly what stamping I'm looking for. Or if I just go, so i know what i'm looking for.
Justin
Old Mar 24, 2005 | 02:59 AM
monsterbaby's Avatar
monsterbaby
Most of them I have seen have the number of teeth stamped into them like 41-10 which I think is the most common although there is probably other combo's of teeth that will be pretty close
Old Mar 24, 2005 | 09:57 AM
hoxiii's Avatar
hoxiii
Thanks man! That's what I thought i remembered it being, but wasn't quite 100%
Justin
blk450er
Sep 13, 2016 10:08 PM
granny_rocket
Oct 5, 2011 06:29 AM
kjgibson2
Jun 9, 2011 11:22 PM
Oregon Bob
Nov 12, 2006 10:22 PM
mudinford
Offroad & 4x4
Apr 8, 2002 07:15 AM
