I was checking A past post on wireing a tack. A previous question was what I needed,But I have another.
When hooking to the - side of the coil my 77 it has a clip, So can I splice into the BROWN wire which is - by the MODULE it is closer to the fire wall
DON
I'99 percent sure the neg. on mine is BROWN not 100 percent, But as long as it's the NEG.---Right Tack-- red to hot
orange to light switch
Black to ground
green to neg side of coil
I don't know what color the wire is on your truck, but yes, you can hook over near the module. In the above diagram, it is the "green" wire.
