FUSE # for battery charge(to trailer)/Which pin on connector?
but, can anyone tell me the fuse # that is for the battery charge, regarding towing a trailer. ...plugged into the large 6 pin (plus the one in the middle)
trailer plug at the back of the truck. Also, can someone tell me which pin carries the battery charge through to the trailer? I know they're numbered in some way, but if you read it clockwise, I would call them 1,2,3,4,5 and 6. Anyway, any help would be great.
As far as I remember, the fuse for the battery charge (trailer) was a 30 amp?
But don't know which number, or location.
By the way it's a '99 PSD F250 4X4
Last edited by LA_BigRed; Mar 11, 2005 at 11:54 PM. Reason: didn't put model or year
Steve
DP
Last edited by bosshoss; Mar 13, 2005 at 01:05 AM. Reason: HIT SUBMIT BUTTON BY MISTAKE
Still not sure about the fuse though. But the fuse for the batt. charge must be ok, since I'm getting 12 V on it (checked w/ voltmeter). Manual's on order and hopefully that'll clear things up. but for the next two weeks, I'll be guessing a little.
For whatever reason, I'm not getting 12 V through all of the pins. Some are around 3 V (turn signals for instance) ..actually the only one I am getting a steady 12 V through is the batt. charge pin. If that's normal for everyone, then I've got nothing to be concerned with.
thanks for the info.
Did you get 12V from the center pin in reverse? You won't get any reading from the brake pin unless you have a controller and relay(s) installed and someone is pushing the brake pedal. The two brake/turn signal pins and the running lights pin should show 12V when the corresponding truck lights are on. Make sure you have a good ground.
Steve
