I just bought a 1990 F250 5.8 with 240,000 miles. I just did a compression check and all cylinders are 140-145lbs after a short warm up period. It does however, smoke at idle and when a friend drove behind me he mentioned the "smoke/oil" smell. This truck will be used to tow a 6500lb boat/trailer combo from CA to Alaska in June and will then be used for only 5 weeks or so every summer when I'm in Alaska. The rest of the year it will sit parked at at friends house up on blocks.
How do I tell if its rings or valves that are letting oil by? If its rings, I might be inclined to do a valve job. If rings I'd rather not pay the 2000.00 that the Ford dealer wants for a new motor.... Would there be any other options? I've rebuilt 6 SBC's but really don't have the time/$$ to spring for a rebuild at this time.
If it is valve stem seals, they usually show up worse when first starting up after sitting because the oil runs down the valve stem past the seals and pools on the piston. Normally after the engine cranks and runs a few seconds the pooled oil burns off and the smoke decreases or goes away.
OK. Checking the rings, pull the plugs, do a dry compression check. Then, squirt a couple squirts of engine oil in the plug holes and do it again. A significant increase indicates rings worn (which goes w/o saying at 200k plus miles. Valves/stem leakage is usually indicated by smoke right after start-up or after idling for awhile. Clears when you run the engine. Sounds like you've just got a tired 5.8. Just for laughs and giggles, try a product called "Restore" in a silver can. Run this for a couple dozen miles and retake the dry compression readings. Let me know what you find, OK?
Restore does nothing that a higher viscosity oil couldn't do. That is the primary benefit to using such products, the uprate in the viscosity of the oil. Rather than go that route, he'd be better off to go with a good 15W40 diesel rated oil to give those rings a bit more chance.
Yeah, I understand about viscostiy, but have you ever looked in one of those cans? Not very viscous...pretty thin. And its blue...and something settles out and if you don's shake it up you don't get it out. Think the viscosity theory doesn't hold here. It's no STP or Lucas, which is very viscous. I've used it and noticed some improvment, but my vehicle wasn't worn quite as bad as his. That's why I suggested it. For $10 or so, it couldn't hurt.
