Clunk sound coming from the rear
Old Mar 7, 2005 | 08:03 AM
ugotkern's Avatar
ugotkern
I have a 97 Expedition Eddie Bauer Expedition with LLS. When ever I go over bumps I'm getting a clunking sound coming from the rear. I've replaced the shocks and the rubber stoppers on all doors and tailgate and the problem still exists. I also have another 97 Eddie Bauer Expediton w/ LLS thats starting to do the same thing but no where near as loud or sensitive yet. Is this a common issue on something working itself loose or a wornout part?
Old Mar 7, 2005 | 02:03 PM
99 Navi Guy's Avatar
99 Navi Guy
Just a thought ........... I had a "clunk" sound as well and found that the spare tire was not quite tight up against the bottom of the bed ......... so it would swing just a bit and make "clunk" sound .......
Tightened it up and now it is a quiet as a mouse ........
Old Mar 7, 2005 | 09:09 PM
saltzy's Avatar
saltzy
Do you have a trailer hitch that might be jiggling? Or did you maybe notice that the bolts that hold the rear shocks were worn a bit? Perhaps one of the shocks needs to be tightened down?
Old Mar 8, 2005 | 06:51 AM
ugotkern's Avatar
ugotkern
Spare tire is tight, hitch is solid, just replaced the shocks and the bolts were fine. I changed the shocks thinking the sound might be related but it wasnt. Just figured since I have 2 identical Expeditions that are now both making this sound that it might be a common issue.
Old Mar 8, 2005 | 09:57 AM
npearman's Avatar
npearman
I have the exact same problem with my 99. It drives me crazy because I can't figure out where it's coming from. I can stand on the back bumper and bounce up and down and not reproduce the noise, but if I go down a road that is just a little rough it sounds like something is rattling against the frame. I've checked shocks, antisway bar connections and tail-pipe, but they all seem tight. The manually pushed on the spare but it seems tight. I might try lowering the spare and cranking it back up, biut I don'tthink that will make a difference. BTW - have you had your rear brake pads changed lately? I changed mine a few months back and was wondering if I did something incorrectly that could be causing the noise.
Old Mar 8, 2005 | 10:05 AM
PaulC's Avatar
PaulC
Wonder if the sliding spline on the driveshaft is binding?
Old Mar 8, 2005 | 11:45 AM
KevinM's Avatar
KevinM
Bet it is the rear cargo door!
Old Mar 8, 2005 | 11:52 AM
ugotkern's Avatar
ugotkern
Its not the tailgate, just replaced all the rubber stoppers/spacers just to see if that would resolve the issue... it didnt. I tried rattling the tailgate and rear glass... its solid. Dont think its the brakes, I have 2 Expeditions and the brakes were swapped out at differant times and we installed them properly.
Old Mar 8, 2005 | 02:51 PM
npearman's Avatar
npearman
where are the rubber stoppers and spacers on the rear cargo door? I don't remember seeing them
Old Mar 8, 2005 | 02:55 PM
ugotkern's Avatar
ugotkern
Rubber stoppers are located on the vehicle upon opening the tailgate about chest height near the tail lights. One on each side
Old Mar 12, 2005 | 11:33 PM
pablocruz69's Avatar
pablocruz69
I have the same problem and I found that there is a metal sleeve that goes over the rear shocks and that was rattleing every time I went over a bump in the road or over a speed bump it was anoying the heck out of me and I looked and sure enough there was that sleeve that went over the shock. I am not sure what the purpose of that sleeve was but that was the problem. I have a 97 Expy.
Old Mar 14, 2005 | 11:40 AM
ugotkern's Avatar
ugotkern
Replaced the shocks originally and that was not an issue.
Old Mar 15, 2005 | 12:10 AM
pablocruz69
I am sorry I can't be more help to you. Good luck!!
Old Mar 15, 2005 | 04:04 AM
Monsta's Avatar
Monsta
Sit. Stay.
When does it clunk? When the springs compress or when the rebound?
In other words...when you HIT the bump or when the truck "comes' back down from hitting the bump?
Old Mar 15, 2005 | 06:02 AM
npearman's Avatar
npearman
mine sounds like it makes the noise when the springs compress but the strange thing is I can't reproduce the sound by jumping up and down on the backend. It seems to rattle/clunk more frequently when I'm going down a rough road as oppose to going over speed bumps.
