1993 4x4 Explorer Transmission trouble
Could this be just a torque converter/bad fluid problem or should I start looking for a new tranny? I don't know what the previous owner put in the transmission for fluid (maybe 5W30 motor oil??), and I've only had the truck about a year. I have put only 7k miles on it since then so I have never serviced it, but never had a problem until about 2 weeks ago. Total milage is 133k.
I was going to try cleaning out the pan with solvent, refilling the case with all new fluid and see what happens but I thought I'd ask here before I waste the time. If it sounds like my trans is bad then after 130k miles maybe I ought to just replace it?
I thought I'd ask here what you all think though before I spend $1,300 on a factory rebuilt trans as opposed to maybe 60 bucks worth of fluid and a new filter. What would you do under the symptoms I described? I would have to borrow the money if I need a new tranny, I dont have $1,300 extra bucks atm.
Thks for the input. Pretty much what I thought anyways but I wanted some input from ppl with experience with ford auto trans.
Also... as mentioned the A4LD is problematic, the 4.0L motors are solid.
The overdrive condition sounds like an issue with the vacuum modulator (a $15.00 part - see other posts on this, there are many) but with the other gears going...???
Good luck with it!!
A salvaged trans might be an option, but there's no way to tell what kind of condition it is in either. I may put it in only to find that it also has problems.
As far as doing a manual 5-speed conversion, I don't want to go there. I have done several engine rebuilds, I did them myself, but I don't have the time nor the tools. The last time I did it was about 10 yrs ago and the car was from the early 80's. I was also using Dad's tools, not mine. I would rather just keep this truck stock as it came from the factory. If the A4LD has issues, this one lasted 133k miles, so a factory rebuilt one should last another 100K.
My question was more or less directed to the torque converter, I can get a new T/C for $160. Would a bad T/C cause the fluid to run black, smell burnt, and lose all gears or is it a matter of bad T/C=Bad Trans? O/D went first, but then the others followed. It started slipping in and out of gear a few weeks ago, and gradually got worse. D,1, and 2 alll worked at first then they too started doing the same thing - and it got worse as the engine warmed up.
I stated that the fluid was viscous for that reason... from what I understand the T/C is just a turbine. Would thick fluid cause it to fail? Why and how did my trans fluid get so thick to begin with? When I drained the fluid it looked and smelled just like motor oil when doing an oil change. Trans fluid has the viscosity of water when it goes in, so how did mine get blackened and thick as oil?
BTW the crack about the previous owner putting 5W30 in the trans case was a joke. No one put oil in the case! The previous owner is my brother in law, although he's no mechanic he does know basic maintenance
My 91 has 220K miles and runs beautifully. There are thousands of these transmissions still on the road too and operating just fine. You may get a bad one at the wrecker but I'd take the chance. Use your 90 day warranty to thouroughly test the unit.
Is your brother vehicle savvy enough not to use a non-Mercon product in the transmission? That would be a problem.
I agree with everything you said, and after a week of thinking about it I have decided the best thing to do is get a tranny from a wrecker since I don't have the $$ for a new one. Most say they can guarantee the mileage that was on the vehicle it was taken from, and most have a 90-180 day warranty. I used a parts locator service and have about 20 e-mails in my inbox waiting for me to call and take my money, so I'll either find one nearby or one who will pay for shipping
I'm still putting a brand new T/C in it since they are only $160.
I don't do Moab or anything but I am a bit hard on it when 4 wheeling, so I'm actually surprised it didn't go out sooner.
thanks for the input.
I have a hard time believing that you can get a "factory rebuilt" transmission for $1200- $1300. I would think you are looking at closer to $2000 but I must admit, I have not priced them.
Also, factory does not rebuild transmissions. In fact, Ford does not even build them anymore, they just buy them and install them. They buying rebuilts from someone like Fred Jones in Oklahoma City and marking them up before selling them to you as "factory rebuilt"
I realize that factory rebuilt doesn't mean "rebuilt at the Ford factory" it just means rebuilt to factory specs. I didn't think it was rebuilt by Ford. I said I had no experience with Auto Trannies, I didn't say I had no mechanical experience.
I maintain the transfer case and the differentials regularly. The differential on Explorer is notorious for not engaging and/or staying engaged so I check the wiring and keep it all clean too, so it isn't necessary to service them at this time. The A4LD trans does not have a drain plug and is supposed to be "service free"... Thanks for the suggestion though. It is a good one and would appply in most cases.
I only wondered if a bad Torque Converter could be the issue since I know (knew I should say) nothing about auto trannies... After doing some research on turbines, torque converters and how they interact with the trans, gearing and schematics of the A4LD along with a few other autos, it seems it would still work even if you did put 5W-30 in it, just not for very long and you would have serious lag on the shifting. It would also get extremely hot and probably completely melt down in about 15 minutes due to the high viscosity of the fluid and the friction it would cause. It would not burn the converter, the stator is made of hardened steel. It would melt the planetaries and their rings, then continue to shoot 5w30 through the molten heap.
I think this is what happened in mine: The fluid started getting overheated, causing the O/D planetary set to stop working, then it went down the line and as I did so it kept getting hotter and hotter and I kept burning the planetary sets until I had nothing left. That would also explain the black molten goop that poured out when I took off the pan. I bet if you boiled a bottle of Mercon III for an hour you'd get the same thing. Makes perfect sense to me now.
Conclusion: The transmission is slag. I will need to replace it, no, a bad torque converter did not cause this I will therefore need to replace the slag heap.
Question answered through my own research and the helpful comments from some nice people who took time to reply and share their knowledge.
You might want to flush out the trans coolent lines and cooler real well befor you put in that rebuilt. You dont want the clutch linning and burnt fluid going through that rebuilt. This is very important. JMTCW Roy.
My mechanic is a guy I know and trust that owns his own shop, and has been working on Fords for 20 years. He gave me a bunch of usefull info, including the fact that the Chilton manual and Ford are FOS about not needing to service this model trans. He says I should do a total flush every 30K miles especially if I am off-roading. Even though there is no drain plug and its more work, he said to do it anyways. He's going to tow it, do the R&R on my provided tranny and road test it after 500miles for 350 bucks, and he said he'll only need 1 day to do it. Plus, I know it will get done right that way and wont worry about it. He will flush it I'm sure, but I'll be sure to mention it when I take it in. He does my major work when I need it, like when I rebuilt the engine in this he did the machining work. I don't have the machinery for that kind of thing. All I did was dis- and re-assemble the parts.
I have learned alot this past week, thanks to this forum and the people who make it happen. I may not be doing a auto trans rebuild, but I learned alot about them and how they work due to this problem.
Good luck
Respectfully
Dean
Did you get a new converter or was it the old one that sent metal chips through your system?
I'm putting a new one in with the tranny, and I'm going to make sure the system is completely flushed before the new one is installed. One good thing about having a mechanic do it is that if something goes wrong within their warranty, they fix it for free.
BTW - "Duhhh!!!!! Of course I priced them. Did you think I pulled those figures out of my crack?" - Very childish and uncalled for. We are trying to help one another here. This "derogatory" sarcasm does nobody any good and indicates a lack of appreciation for those trying to assist you. Remember that there is a good chance someone on this forum has already dealt with whatever issue you are facing and have a great deal of experience to offer. If you don't want our help, don't ask for it.
Had you been clear on pricing as you were in the later post instead of using dollar figures rounded to the nearest hundred, it would have indicated to me that you did price the transmissions. Instead it sounded like you were pulling numbers out of the air.
Your local transmission shop will re-builld a transmission to factory specs as well. Nothing special about getting one from an auotparts store and probably a point of concern regarding quality. If you buy for the guy down thge street that your neighbor used with some success three years ago, you have some idea that the guy who rebiult the transmission knows what he is doing and you can speak with him in person if there is a problem. There is nothing more frustrating than having to pull a replacement transmission that does not work and I have experienced this first hand. This is another reason that I recommended a tranny shop. That said, I hope that whatever you choose to do works out for you.
