40 front clip on 47 pickup?
Old Feb 3, 2005 | 11:07 PM
fastestford's Avatar
fastestford
Question 40 front clip on 47 pickup?
Will a 39 or 40 pickup or car front clip fit onto a 47 pickup without heavy modification? I have been told that the 40 and 47 pickup cabs are the same. Is that true? I know where a cheap 47 pickup is and I have 39 Deluxe car front clip but figure they won't match up. Thanks!
Old Feb 4, 2005 | 06:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 4, 2005 | 07:52 AM
Elder Rodder's Avatar
Elder Rodder
40-47 Ford PUs have the same cab that will fit on a 40 PU frame without modification. That would mean that you can take a 47 (1/2 ton PU) Ford cab to a 40 (1/2 ton PU) frame. This just the opposite of what you want to do. Forget the 39, that's different. Forget cars, they're different.
havi
1947 and Older Ford Trucks
Apr 20, 2013 06:16 PM
riddleswest
Jul 30, 2012 08:13 PM
46yblock
Aug 20, 2009 07:23 PM
mp40pickup
Oct 20, 2008 08:07 PM
jim72051
Feb 26, 2007 10:42 AM
