LSD for a 94 f150
Old Feb 2, 2005 | 12:42 AM
GasMonkey's Avatar
GasMonkey
LSD for a 94 f150
i have an automatic transmission 94 ford f150, where could i get a limited slip differential for it? and about how much would it run me?
Old Feb 2, 2005 | 03:18 AM
Ponyracer's Avatar
Ponyracer
there is not a limited slip part available for the transmission only the front and rear differentials. Is that what you are after?
Old Feb 2, 2005 | 09:29 AM
GasMonkey's Avatar
GasMonkey
well, id like to improve power getting to the wheels, would gettting a limited slip differential for the rear axel improve traction by a lot?
Old Feb 2, 2005 | 03:19 PM
Ponyracer's Avatar
Ponyracer
what is the vehicle and what options and additions does it have?
A limited slip will help greatly with traction not power, gears will help with power/torque.
Old Feb 2, 2005 | 08:23 PM
SoCalDesertRider's Avatar
SoCalDesertRider
If this is for the '94 F150 you mentioned, there are a number of limited slip differentials available for that rear axle, as well as locking differentials and selectable-mode differentials too. In an F150 of that year, the rear axle is a Ford 8.8". If the truck is 4wd, the front is a Dana 44 TTB (twin traction beam).
You might want to go to one of these websites (listed below) and read about what differentials in general do and how they work, then read about the different choices of aftermarket traction differentials available and how each one works, to better make an informed choice about what kind may be best for your intended use.
www.reiderracing.com
www.ring-pinion.com
Old Feb 2, 2005 | 11:48 PM
GasMonkey's Avatar
GasMonkey
yea i have a 2wd 94 f150
also, would getting a limited slip differential for the front and back help with the turning radius of the truck?
whats a ball park figure for these differentials? and where can i get one?
Old Feb 3, 2005 | 06:53 PM
SoCalDesertRider
GasMonkey, the front/rear differential choice is going to be pretty easy for your situation- since your F150 is 2wd, you can only put one in the back axle. The front axle doesn't have a differential at all, as there's no power going through it, it just holds up that end of the truck.
Traction differential prices range from about $300 to $1000. Most are in the $300 to $600 range. The selectable lockers (E-Locker, Electrac, ARB, etc) are the most expensive and the easy-install caseless auto-lockers (EZ Locker, Lock Right) are the least expensive. Most of the limited slips are priced in the middle ground (Eaton Posi, Trac Lok, Auburn, etc).
Old Feb 3, 2005 | 07:16 PM
SoCalDesertRider
Sorry, double post.
Apr 12, 2004 04:43 PM
ILovePkr
Mar 29, 2004 09:56 PM
countryboyf150
Dec 20, 2003 02:10 PM
94I-6
Oct 9, 2003 10:42 AM
deleontow
Nov 27, 2000 09:43 AM
