What type of sealant to use on box
Hi, i bought two used infinity subs with a kenwood 800watt amp.. the subs came in a 9x12x12 box, or .75cubic feet for each speaker. The box dosent fit behind the seat in my 86f250 reg cab, so I used some math from school and designed a triangle shaped box that has roughly .75 cubic feet of air. I'm making a run to home depot in a little bit, so what type of wood should i buy, and what type of sealant should i put in between the wood?
My box dimensions are 6" on the bottom, 17" tall and 35" wide and a 2 inch flat spot on the top ,it should fit perfectly behind the seat and allow me to mount my amp on front
I got a tip to use Liquid Nails for the sealant if you're worried about silicone. I dropped a thick bead on all the joints, drywall screws, and then laid another thick layer on all the beads inside the box with Liquid Nails. Just like maticuno except I didn't use any silicone.
I also take it a step further and run a bead on all the outside joints to make sure all the seams are filled in and smooth them out with a putty knife. That way I know there shouldn't be any leaks on the box. Makes them rock solid too.
