where are the IAC AND MAF sensors in a 1996 ranger?
Old 01-12-2005, 03:07 PM
fimar7's Avatar
fimar7
fimar7 is offline
Question where are the IAC AND MAF sensors in a 1996 ranger?
Hello,
I need to know where is the iac and maf sensors in my ranger 1996 single cab, 5 speed manual, gasoline. Also, if it possible to send pictures about the phisical location. Thanks in advance.
Old 01-12-2005, 06:00 PM
el conquistador's Avatar
el conquistador
el conquistador is offline
depends on which engine you have. generally the maf is right next to the air box and the iac is on the throttle body or upper intake.
this is the IAC
i cant find the pics of the maf from previous posts.
the maf sensor is black and flat and is held on with two torx screws, its mounted in between the air box and the air tube, my sensor says "mass air" on it. when you take the sensor off there will be two filliments so be careful they are fragile.
kegomatix
Escape & Escape Hybrid
03-04-2017 06:32 AM
shultzaberger
04-18-2016 07:57 PM
KLF94
08-04-2015 11:30 PM
tallahassee bronco
1978 - 1996 Big Bronco
05-25-2012 04:37 PM
Ceo4sure1day
18
08-21-2011 09:14 PM
Quick Reply: where are the IAC AND MAF sensors in a 1996 ranger?
