Dana 60 rear wheel seals kept leaking
Old Dec 28, 2004 | 10:09 AM
ranger-g's Avatar
ranger-g
My truck is a 79 f-250 4x4. problem: dana 60 right [ passenger side ] seal kepts leaking. The garage has been very good at replacing the seal. the seal last for about 500 miles. all tha parts looks to be in good shape. all the surfaces look good, thats what the shop says. any ideas out there? have any of you run into this problem?
Old Dec 28, 2004 | 12:35 PM
cannonfodder's Avatar
cannonfodder
Put a speedy sleeve on the spindle just to be sure it seals. Moe
Old Dec 28, 2004 | 02:45 PM
ranger-g's Avatar
ranger-g
it had a speedy seal on it the last time. it still end up leaking after about 500 milies.
Old Dec 28, 2004 | 04:12 PM
buzzbait65's Avatar
buzzbait65
bent spindle
I will assume it is a full floater.....if the spindle was bent slightly on the axle tube side, wouldnt the seal run off center and eventually wear very fast
Old Dec 29, 2004 | 09:36 AM
mark a.'s Avatar
mark a.
Are you sure the vent tube is clear ?
Old Dec 29, 2004 | 05:32 PM
ranger-g's Avatar
ranger-g
yes vent tube is clear. also the shop stated that the dust seal is ripping then gets caught on the seal itself then begins to leak. they say everything is good: axel,spindle where the seal sets. they do not know what the problem is.
Old Dec 29, 2004 | 07:03 PM
cannonfodder
Not to be insulting but I think you should consider a new mechanic.Moe
Old Dec 30, 2004 | 06:19 AM
mark a.'s Avatar
mark a.
I would try putting the seal on the spindle before you drive it into the hub & see how it's fitting. It should fit tight, hard to turn by hand. Also when putting the drum on don't let it hang there without the outer bearing in, that can damage the seal.
Old Dec 31, 2004 | 07:23 PM
ranger-g's Avatar
ranger-g
the auto shop put on a differant seal, made by sombody else. maybe a bad set of seals? i will let you know if this works.
kmjone00
Jan 6, 2022 08:32 AM
Vijay
Jan 7, 2017 10:14 PM
Aaron-71
13
Nov 10, 2016 02:39 PM
TireJockey
84
Jul 19, 2015 10:03 AM
ford_nut
Jan 28, 2003 01:59 AM
