fuel leak under the filter
Old Dec 21, 2004 | 02:40 AM
petestruck's Avatar
petestruck
Question fuel leak under the filter
This is my first 95 7.3 I changed the two easy fuel lines and hoped it wasent the bottom one but it looks like the hose under the filter, anyone know how hard it is to change it? looks like two bolts hold down the fuel filter but is there more? any tips? sure appreciate any help Thanks
Old Dec 21, 2004 | 03:14 AM
fedextech's Avatar
fedextech
that hose on the bottom is a little bit harder to get to, just remove the 2 bolts on the filter housing, remove the hose from the low pressure pump to the filter housing to allow more room and to allow movement on the filter housing...and then remove the bottom hose ( hi-pressure pump fuel supply). you need to check a couple of other areas for your fuel leak...the vacum/pressure switch on the back of the filter housing (black with 1 wire on it)...the filter housing itself will leak around the bottom from corrosion on the inside...the mechanical fuel pump ( 2 pumps in one) there are 2 weep holes and you can check these with a mirror...and the fuel filter lid seal could leak. hope this helps.
Old Dec 21, 2004 | 06:07 PM
petestruck's Avatar
petestruck
Smile thanks so much!!
Thanks a lot I feel a lot more confident now and I will also check thoes areas you mentioned. my local mechanic wanted $400 bucks and I just dont have it, thanks again. Pete
Old Dec 22, 2004 | 01:57 AM
fedextech's Avatar
fedextech
your welcome!
jonrjen
6.7L Power Stroke Diesel
Jul 2, 2014 11:33 AM
TXBob
Feb 22, 2007 10:28 PM
jamesemery728
1983 - 2012 Ranger & B-Series
Aug 13, 2005 07:00 PM
emilbanks
Sep 15, 2003 08:20 PM
cobaum
16
Jun 21, 2003 05:18 PM
