Cracked headlight housing
Old Dec 13, 2004 | 05:51 PM
fordtrucklover94's Avatar
fordtrucklover94
I recently had a bulb burn out and took the time and money to go ahead and replace them both. I replaced the passenger side one out no problem, went to pull the driver side bulb out and heard a pop, my first thought was oh crap, pull it off and sure enough part of the housing had cracked. My question is, is it ok for this, the spot in the housing is covered by the black piece that surrounds the base of the headlight. Thanks for ya'lls help
Old Dec 13, 2004 | 06:57 PM
maticuno's Avatar
maticuno
The only thing I could possibly see happening with a cracked housing would be moisture entering. I'm not sure what all problems would come from that, but a new housing is only about $40 on eBay.
Old Dec 13, 2004 | 08:35 PM
Ken00's Avatar
Ken00
I would just seal it up, the moisture & dirt will shorten the bulb life.
Old Dec 13, 2004 | 08:39 PM
fordtrucklover94
what should i seal it with, just silicon?
Old Dec 13, 2004 | 08:46 PM
Ken00's Avatar
Ken00
That would work, I would use a thicken epoxy if you need to strengthen the housing.
Old Dec 14, 2004 | 10:41 AM
fordtrucklover94
sounds good, thanks ken
