2004 f150 audio connector PINOUT and wire color information for single cd system
Old Dec 7, 2004 | 03:26 PM
mkoser's Avatar
mkoser
Lightbulb 2004 f150 audio connector PINOUT and wire color information for single cd system
I went ahead and did the dirty work yesterday of metereing and testing everything to find which wires go to what, because I could not find it on the web anywhere.
Here is a complete list if what goes where. These are all located at the plug end, going into the radio. Switched 12V+ may be a different color, but it is located in the same position! Whoop! Whoop!
Thanks,
MK
2004 F150 Radio Wiring
Green/Violet: Constant 12v+
Black Green: Ground -
Pink/Black: Switched 12v+
Orange/Light Green: Left Front +
Grey/Light Blue: Left Rear +
Orange/Red: Right Rear +
White/Light Green: Right Front +
Dark Green/Orange: Right Front -
Light Blue/White: Left Front -
Tan/Yellow: Left Rear -
Brown/Pink: Right Rear -
Any questions let me know,
MK
Old Dec 7, 2004 | 04:06 PM
SteveVFX4's Avatar
SteveVFX4
you could have just stopped by your local dealer and talk to a service guy and see if he would let you look through the F-150 wiring manual. That's what I did when I was trying to research the Audiophile plug layout and wires. He even let me photocopy whatever pages I wanted out of the book. I know the radios were in there too.
btw, if anyone needs to tap into the rear speaker wires, they run along the driver's door sill with a bunch of other wires. And the speakers wires are unique because they are twisted together. For example, the left speaker wires, grey/light blue and tan/yellow are twisted together. The right rear speaker wires must turn and go across the floor behind the front seats. This was in my Screw. I just tapped into the left/right rear speaker wires for my high level input into my sub amp I just added.
Old Dec 7, 2004 | 04:23 PM
HammerFX4's Avatar
HammerFX4
Is there a plug in there to hook-up Sirius sat radio?
Old Dec 7, 2004 | 11:42 PM
mkoser's Avatar
mkoser
no.
mkoser
Old Dec 7, 2004 | 11:47 PM
mkoser's Avatar
mkoser
btw
My closest ford dealer is 56 miles each way. I don't really like them to begin with, and I am not going to drive that far to get something that I discovered myself. I just thought I would post that info here so others can benefit from my work.
This simplifies the whole deal, and isn't as complicated as the wiring diagram books.
MK
Old Dec 8, 2004 | 10:29 AM
nateo44's Avatar
nateo44
Thanks for your efforts. That will come in VERY handy!
Old Dec 8, 2004 | 03:03 PM
Firewiz's Avatar
Firewiz
Thanks mkoser...fyi though...most color combos on the wires are fluent with all vehicles made by ford. More than likely the same colors are true for a mustang as for a f150.
Some info here :
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
Old Dec 8, 2004 | 08:36 PM
mkoser's Avatar
mkoser
My 1997 Expedition wasn't anything close to this.....
I thought the same thing too, so I took the radio out of the expy to compare and wasn't the same.
MK
Old Dec 8, 2004 | 10:58 PM
Firewiz's Avatar
Firewiz
Yep-it prob was this scheme (97 and older) :
Right Rear Spkr (-) Blue
Right Rear Spkr (+) White w/ Blue Stripe
Right Front Spkr (-) White
Right Front Spkr (+) Blue w/ White
Left Rear Spkr (-) Red w/ Blue Stripe
Left Rear Spkr (+) White w/ Blue Stripe
Left Front Spkr (-) Blue w/ Orange Stripe
Left Front Spkr (+) Purple
Ground Wire Black
Dash Light Dimmer Wire Orange (if available)
+12 Volt Ignition Wire Blue w/ Black Stripe
+12 Volt Battery Wire Blue w/ Red Stripe
Old Jan 4, 2005 | 06:15 AM
macaroni22's Avatar
macaroni22
Thanks for posting your research, this helps me, I am gonna use it today!
Old Jun 18, 2013 | 11:48 AM
okstatef150's Avatar
okstatef150
I'm trying to wire a amp up to my stock head unit, but I can't find the AV cable port on the head unit. What am I missing, I've pulled the radio out, and it seems simple enough, yet no ports. Thanks guys.
Old May 5, 2015 | 10:55 PM
Idaho F150's Avatar
Idaho F150
Need help with 06 installation please...
...my stereo installation guide says it can only be used with 12v DC power supply negative ground. What does this mean? & which truck wire (blk/green or black) do I connect to blk stereo ground wire? Installation guide says "be sure to ground this unit to the cars chassis again after installation". How do I connect ground wires correctly?
Thanks,
MK
MK
Old May 5, 2015 | 11:01 PM
Idaho F150's Avatar
Idaho F150
...my stereo installation guide says it can only be used with 12v DC power supply negative ground. What does this mean? & which truck wire (blk/green or black) do I connect to blk stereo ground wire? Installation guide says "be sure to ground this unit to the cars chassis again after installation". How do I connect ground wires correctly? And to which truck wire do I connect red ignition wire?
Thanks,
MK
MK
Old Sep 23, 2015 | 03:17 PM
Joey Lara's Avatar
Joey Lara
I have a question my headunits resets evrytime i turn my truck on and off. Do you know why this could be happeneing?
White97
15
Mar 24, 2017 08:40 AM
BAJACRAZY32
Nov 11, 2016 08:09 PM
lunar68
Jun 2, 2016 01:53 PM
Murphy's Law F-150
Mar 16, 2016 01:16 PM
97Fordf35089f250
20
Dec 31, 2015 12:25 AM
