What could be causing a catalytic converter to burn up?
Old Nov 24, 2004 | 11:09 AM
95_mazda_b23's Avatar
95_mazda_b23
Well, today I went to go to the local muffler shop that originally did work for me about a month or two ago because I have had some rattling in the back of my truck since the last time I had brought it in, and they told me that the cat had burnt up. They said it had something to do with an EGR valve and possibly some other problems (the EGR vavle I guess being the main reason considering that is the only one he really made a point to bring up) and so I was talking to my dad and he had said that when we had pulled codes on it before, it had brought that up. He also said that it shouldn't be the cause of the problem. The mechanic however said that since the fuel that doesn't get used isn't recycling that it is helping burn up the cat. Now to be honest with you I trust my dad, but what this mechanic told me kind of makes sense. Could anyone enlighten me on what's going on here?
I have a 1995 Mazda B2300, 4Cyl, Auto, Short Bed, Std. Cab.
Thanks in advance and if you need any extra info, please feel free to ask.
Old Nov 24, 2004 | 11:34 AM
muscletruck7379's Avatar
muscletruck7379
how many miles are you at?
Old Nov 24, 2004 | 11:40 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The EGR returns some exhaust to the intake and lowers combustion temps; this benefits emissions (NOX). The PCM will adjust the fuel/air mixture so there is no loss of performance. Any fuel returned to the intake is of minute quantities, therefore your dad is correct. I've never heard of an EGR issue that results in a failed converter. Missfire or an overly rich mixture on the other hand, will contribute to converter failure. Back when leaded gas was available, this was a dandy for taking out converters.
You're not adding anything to your gas are you?
Old Nov 24, 2004 | 12:15 PM
95_mazda_b23
About 94,500.
Ok, that's good to know. When you say add anything to the gas what do you mean? About a month or so ago we added a Carb/Fuel Injector Cleaner and my dad said for the first few fill ups to put premium in it and after that go back to regular.
Also, what you said triggered something else I remember the mechanic saying. He said something about it was running rich. What could he have meant by that and what could cause that and help fix it? Thanks again!
Old Nov 24, 2004 | 12:41 PM
G2IC_Wraith's Avatar
G2IC_Wraith
What he ment by "running rich" is that there is too much fuel going into the engine for it to run at peak performance. Generally speaking a good air/fuel mixture is 14.7:1 and is controlled by your computer with the help of things like the o2, MAF, IAC, etc..... Something like a dirty sensor will fool the computer into putting too much fuel into the engine. In turn, wasted fuel comes out the exhaust and kills the cat.
(And they say curiosity was responsible for that..... lol)
Old Nov 24, 2004 | 12:53 PM
CowboyBilly9Mile
I was wondering if you might come back and say you were experimenting with naphtha in the gas.
Evidence of running rich: poor gas mileage, spark plugs have black, sooty deposits, and after the engine is fully warm an excessive rotten egg smell to the exhaust.
Old Nov 24, 2004 | 05:11 PM
psycocrazy's Avatar
psycocrazy
you might also want to check your O2 sensor. if its runnin rich your sensor can crap out on you and help screw up your cat. that happened on my 89 ranger.
Old Nov 24, 2004 | 07:43 PM
Higgin's Avatar
Higgin
I always think this is an interesting topic because back when i had my 98 dakota, I had the cat replaced 2 times before the warranty expired at 36,000 miles. The second time, it even clogged the exhaust so that it wouldn't rev over about 2 grand. Luckily, nothing broke (that was before I knew much of anything about cars....would never do that again..). The second one went out at like 20,000 miles and I said if it went out again, I wasn't letting the dealer get out of it by saying "they weren't sure why". But, suprisingly, it never broke again, and I had it till about 65,000 miles. Never did figure out what caused it though, just thought it was odd that it happened 2 times, but never again.
Old Nov 24, 2004 | 07:52 PM
95_mazda_b23
Wow thanks for all of the replies! I was talking with my dad and what he said was happening was that the purge hose needed to be replaced and that we needed to either clean off or get another EGR Valve and that should fix the running rich problem. Then go back and get the cat replaced. Thanks for all your help!
