Evidence of an accident?
Old Nov 22, 2004 | 05:47 PM
jonm61's Avatar
jonm61
Ok, so I posted before about my right fender not lining up on my '99 4dr and someone mentioned that maybe it had been wrecked & for whatever reason Carfax missed it. I know think that's a pretty good bet.
I noticed on my hood today that there is a stamp on the right side, pretty much right above the air filter box that has the Ford logo & 1995. I'm guessing that means the hood was made in 1995 and they probably don't keep too many 1995 hoods lying around to install on a '99 coming off the line....so my hood was replaced.
I don't see any overspray or any other indications of a wreck. Assuming the hood & right fender were damaged at some point, what else should I look at? I want to find as much info as I can now, before things start falling apart on me.
So far, I've had to replace the right lower ball joint & I hear a noise, kind of a clunk, when the wheel is turned all the way to the right.
Any opinions?
Thanks!
Old Nov 23, 2004 | 01:53 AM
red bud's Avatar
red bud
If the 95 and 99 are the same body style, it might have a 95 stamped on it from the factory. I work at Ford and the hoods or the fenders, can't remember, on the vehicles we make are stamped 1997, and we are building 2005's, that is because they never changed them, so they just keep using them.
Old Nov 23, 2004 | 08:14 AM
jonm61's Avatar
jonm61
Thanks Red Bud!
Can someone with a 98-00 check & see if their hood is stamped 1995, just for reference?
Thanks!
Old Dec 6, 2004 | 09:04 PM
vicv's Avatar
vicv
I can tell you my 97 has 1995 stamped on it.
Old Dec 7, 2004 | 01:34 PM
jonm61's Avatar
jonm61
Exactly what I needed, thanks!
Old Dec 7, 2004 | 03:15 PM
mason's Avatar
mason
I thought I read on this forum sometime back that Ford made the hoods about 1/4" difference in size between the 95-97 and the freshened up versions that came out in 98. Maybe you have an older style hood on your 99 causing the problonem.
Mas
Old Dec 7, 2004 | 05:31 PM
jonm61's Avatar
jonm61
Ok, so back to....can someone with a 98 or later tell me if they have this 1995 stamp on their hood?
Thanks
Old Dec 10, 2004 | 07:54 AM
RA71625's Avatar
RA71625
Banned
Jonm61:
Just checked my 98 Sport .... 1996 stamped on it.
Kevin
Old Dec 10, 2004 | 08:50 AM
jonm61's Avatar
jonm61
Originally Posted by UncleWord
Jonm61:
Kevin
Thanks much!
