Predator...Invalid License?
Old 11-18-2004, 06:06 PM
Sidewaze's Avatar
Sidewaze
Sidewaze is offline
I received the Predator today, and while installing the 65 HP tune it didn't recognize a "Turn Key On" prompt. The install failed. Now, no matter what I try to do, I get "Invalid license. The tune in this vehicle does not match the last tune written"
Of course I live on the West Coast and both Diablosport and Motorhaven have closed for the day.
Any suggestions?
Tim
Old 11-18-2004, 07:25 PM
Bear Hunter's Avatar
Bear Hunter
Bear Hunter is offline
Any suggestions?
Tim
Im not familiar with the Preditor...but aren't you able to update the tuner via the web?
Old 11-19-2004, 12:41 AM
SBV45's Avatar
SBV45
SBV45 is offline
Use a battery charger hooked to the primary battery. You must have all electrical accessories turned off. Any voltage change will terminate the program. Then try to restore the original tune. Then try to load the 65 tune.
Old 11-19-2004, 07:54 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,496 Likes on 2,149 Posts
OK, Invalid License
What this is....you screwed up. Read your manual and call Diablo direct. Any power draw when installing a tune will interupt the process. Unhooking your battery will not work because it is not the truck, you need Diablo to reset your tuner.
It is no big deal.... I did this once by mistake, I admit it...
Nothing is wrong, you just need a reset, so call Diablo and they will help. You need to access your truck with a phone so you can plug the programmer in as they talk you through the reset.
Old 11-19-2004, 11:21 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Any suggestions?
Tim
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Old 11-19-2004, 12:31 PM
Sidewaze's Avatar
Sidewaze
Sidewaze is offline
Thanks To All
I spent some time with Diablosport's Tech Support. Brian was great. He led me through the password and now everything works great.
BTW when this happened it threw a P1000 code. Something about incomplete system rediness test. I have cleared it and it hasn't returned. Would a voltage drop combined with the programming cause that?
Anyway, I love the added horsepower and torque. Thank you to all who replied!
Tim
Old 11-20-2004, 11:53 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
The P1000 is normal anytime the PCM is reset, reprogrammed or the battery disconnected.
Matseffie
Australia Chapter
11-24-2014 09:53 PM
briansortland
Computer Chips & Tuners
09-04-2008 07:32 PM
DeckedoutF150
03-21-2006 08:57 PM
DL
04-07-2005 08:49 AM
renkenj
19
09-02-2004 08:49 AM
Quick Reply: Predator...Invalid License?
