How to remove crown vic axles?
Old Sep 19, 2004 | 08:32 AM
illuminance72's Avatar
illuminance72
I am going to do a rear disc swap for my 72 Ranchero using 92 Crown Vic brakes. I am having difficulty removing the rear axles from the CV. I can pull 9" axles out no prob., but this has me stumped. I am *guessing* that something needs to be removed in the carrier. I pulled the cover. There are 4 large bolts (3/4) holding caps on each side. I removed them, but still wont come out. Does anyone know how to remove these axles? I need the backing plates. Thanks
Old Sep 19, 2004 | 08:37 AM
GLR's Avatar
GLR
there is a bolt (5/16 wrench ?) that holds the spyder gear shaft in place. Remove the bolt, slide the shaft out, now the axles will slide in enough to remove the "C" clip that hods them in place. With the clip removed the axles will pull out.
Old Sep 21, 2004 | 12:40 AM
illuminance72
Thank you GLR.....great advice, came right out!
Old Sep 21, 2004 | 12:15 PM
Boss_358's Avatar
Boss_358
Illuminance72, I would like to hear how your disc brake swap worked out when you get it all completed.
StatikPulse
16
Jan 30, 2015 01:08 AM
sledman3064
Sep 30, 2014 10:03 PM
72sleeper
Jun 24, 2013 06:48 AM
jpmanyhearts
May 9, 2012 01:08 PM
