Oil Psi.
Old Aug 21, 2004 | 07:52 PM
ditto's Avatar
ditto
Question Oil Psi.
I wanted to ask some wrench heads about this. Ok i was driving down the highway when my engine light came on. (oil engine pressure) so i was like??? but when i hit the throttle it went away. so i was like wtf? so after reading up on it alittle. I got aftermarket gauges ( volt, water temp, and oil pressure) well. after installing that i found that my truck was running about 10-20psi at idle. i was like ahh 20's seem ok. but then i checked and i was leaking from a valve cover gasket so, being the person i am i fixed that right away. but now my oil pressure is more around 35-40psi.so that comes to my question. Is it all cause a valve cover gasket?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 21, 2004 | 08:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Not likely,
Mine idles at 20 hot 50 cold
It runs at 52 at 2000 RPM hot
Old Aug 21, 2004 | 09:30 PM
ditto's Avatar
ditto
Wink
thanks, i just did another test run and it's staying around 15's-20's hot, 40-45 at high rpm's (2000). i do love this truck . thanks again for the quick response
