ac on 1999 Ford Ranger ELT 4cyclender
Old Aug 12, 2004 | 10:24 AM
dbeaudry's Avatar
dbeaudry
My ac blows out of the defroster instead of the dash, it will change on its own, when accelarating or de-accelarating, please advise what I need to do, thank youu
Old Aug 12, 2004 | 01:48 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Sounds like either a vacuum leak regarding the climate controls, or the blend door is going down the tubes. The blend door issue is common to both the Explorer and Ranger, which are set up the same way.
http://home.earthlink.net/~kandc1/fo...nddoorfix.html
Old Aug 12, 2004 | 02:09 PM
Vin 95's Avatar
Vin 95
You've got a bad vaccum check valve.when you are idleing you have good vaccum and the control works right,when you accelorate,you loose vaccum and the selector goes to the default possition ( defrost ) . there is a check valve that is supposed to hold vaccum on the control when you accelorate.mine did the same thing, but I could'nt find the little bugger and ran a bypass vaccum line and a $2 check valve from auto zone and it works great now.You could probably talk to someone at ford and find out the location of the valve ,they have a vaccum diagram that shows the location.
Old Aug 22, 2004 | 11:44 PM
dbeaudry's Avatar
dbeaudry
Vacuum Reservoir ???
Can someone tell me where the vacuum reservoir is located on a 1999 Ford Ranger, 2.5, I have looked everywere ! ! Thanks
Old Aug 23, 2004 | 12:16 AM
Rockledge's Avatar
Rockledge
Vacuum Reservoir Tank
'99 Ford Manual says:
Vacuum Reservoir Tank and Bracket
NOTE: The A/C vacuum reservoir tank and bracket (19A566) is located either on or beneath the RH front fender splash shield (16102) .
Removal
1. If the A/C vacuum reservoir tank and bracket is visible from above in the engine compartment, perform Steps 2 through 4. If the A/C vacuum reservoir tank and bracket is not visible in the engine compartment, perform Steps 5 through 8.
2. Remove the screws and the A/C vacuum reservoir tank and bracket.
3. Disconnect the vacuum supply and outlet hoses.
4. Disconnect the vacuum hose from the back of the tank if equipped with 4-wheel drive.
5. Remove the engine air cleaner (ACL) (9600).
6. Remove the RH front fender splash shield.
7. Remove the nuts and remove the A/C vacuum reservoir tank and bracket.
8. Disconnect the vacuum supply and outlet hoses
Installation
1. Follow the removal procedure in reverse order
