Vacum Leak? / Misfires / System Too Lean...(P0303 & P0308 - P0171 & P0174)
Old Aug 10, 2004 | 09:18 AM
tooltime4677's Avatar
tooltime4677
Red face Vacum Leak? / Misfires / System Too Lean...(P0303 & P0308 - P0171 & P0174)
I have checked the other "threads" on this site regarding the "System Too Lean (Bank 1 & 2) OBD II codes, and have checked the PVC Valve connections, and still I'm having trouble with misfires on 3 & 8.
I have replaced the coil packs and spark plugs, front O2 Sensor, and still no luck.
Would it be possible (since 3 & 8 are connected through the intake manifold) that there may be a faulty head gasket around one or the other cylinder, causing the vacum leak...or lower than normal fuel pressure here?
I'm stumped!
Old Aug 10, 2004 | 05:04 PM
radtec's Avatar
radtec
Did you test the plug wires themselves
Old Aug 11, 2004 | 08:14 AM
tooltime4677
Wires
I assume that you are referring to the Coil Pack connectors, as there are no conventional Plug Wires...Yeah, I checked them all and they have current running to them.
Thanks for responding,....any ideas about the head gasket???
Old Aug 11, 2004 | 08:40 AM
radtec's Avatar
radtec
I seemed to remember there were long boots on these from a friends truck I was calling that a plug wire. I thought I had replaced one of these one time because the current it was carrying was different from the others nearby and that solved the problem but my memory may be wrong may have been different make of truck.
Old Aug 11, 2004 | 08:50 AM
radtec's Avatar
radtec
I have seen vacuum leaks occur due to bad gaskets on intake manifolds or plenums. But never had one off a expy just a idea.
Old Aug 12, 2004 | 09:17 AM
tooltime4677
Plenum Gasket
Thanks for the idea. Just had another look and the "damp" area is on the side of the head, not the bottom, inside the plenum around cylinder #8, ...maybe the bolts came loose. I'll re-torque. It owes me nothing, as it's in great shape with 244,000 Kms on it.
Thanks Again!
Hoss
Old Aug 27, 2004 | 10:07 AM
tooltime4677
Fixed!
Changed the Intake and Plenum gaskets. That fixed the Vacum leak.
Checked the Coil Pack with a multimeter, and one of them was "dead".
With a Mechanics stethoscope, checked the injectors, and found two of them not "clicking" like they should. Rplaced one coil pack and two injectors, and, low and behold, it's running like new again.
Thanks for the suggestions everybody!
Hoss
CharlesNChargee
Electrical Systems/Wiring
Jul 9, 2024 07:57 PM
payntertk31
Escape & Escape Hybrid
16
May 11, 2020 09:12 PM
Wildboy402
2004 - 2008 F150
Dec 24, 2015 12:42 AM
Dino195
1997 - 2003 F150
Aug 15, 2012 05:26 PM
MrBookworm
Jan 28, 2006 09:47 PM
