Special tool to remove a headlight?
Old Jul 22, 2004 | 04:38 PM
jwramc's Avatar
jwramc
Question Special tool to remove a headlight?
I've run into one of Ford's 'better ideas' while replaicing all my '95 F150's front lamps with diamond-cut units. Apparently, in all Dearborn's wisdom, we are protected from headamps that spontaneously eject from the vehicle by the invention of a Edited for content by FTE clip that holds the adjusters to the steel panel behind them. I'm told I need a unique tool (that nobody local seems to sell) to pull these E-clip-type things up and off so that the headlamp will come out. Hmm....after dealing with headlamps falling out of my prior vehicles a total of ZILCH times, Ford found a cure for a non-existent disease! Kudos!! Now my truck sits, lights tossed aside, bulbs hanging, trim...somewhere I don't recall anymore....while I sit here, venting at you folks. In the 90-degree heat, it was best I stop, cuz I was looking at the crowbar a little too long.
I tried to side-step this moronic procedure by turning the adjusting screws out all the way, but NATURALLY, the top/inner on the driver's side is seized and stripped.
Sooooo.......any ACTUAL 'better ideas' out there???
Old Jul 22, 2004 | 07:59 PM
jwramc's Avatar
jwramc
Oh, nevermind. I made my own work-around.
Whoo...weeee.....my truck looks SWEET with them new lights!
Pictures in the morning!
Old Jan 17, 2005 | 04:57 AM
93f250pos's Avatar
93f250pos
how did you get the lights out?
Old Jan 17, 2005 | 07:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 17, 2005 | 10:10 AM
wickymustang's Avatar
wickymustang
Im anxious to see the pics, how did you end up getting the old lights out anyways?
Old Jan 17, 2005 | 01:07 PM
AlfredB1979's Avatar
AlfredB1979
Those clips = PITA on my Ranger when I replced my yellow headlamps with Euroclears.
I swear it felt like I would lose a finger or three pulling them off!
mikecrom83
Jun 7, 2013 02:30 AM
cdmm151
2009 - 2014 F150
23
Oct 17, 2012 06:31 AM
jman724
1983 - 2012 Ranger & B-Series
Dec 1, 2005 09:04 PM
ozenator
2004 - 2008 F150
Jul 17, 2005 10:18 PM
huronfarmer
Feb 6, 2005 08:04 PM
