1981 f 150 6 cyl 4 speed
Old Jul 17, 2004 | 07:53 PM
hster's Avatar
hster
I assume this must be a 6 cyl flat heat - 6 plugs on 0ne-side. I am having a serious blowby problem. PCv leaking oil down the side of engine.Should I try & clean pcv valve & add some engine restorer ( additive) , or what do you suggest? Also, I just changed valve cover gasket and oil pan gasket. Stll have oil leaking ( fair amount) at back of oil pan where meets tranny. Must be rear main seal ,right? if so, any ideas how to change it without dropping tranny? I was able to get oil pan gasket with dropping the trans.
Any ideas are greatly appreciated.
Please help no money for a rebuild yet!!
Old Jul 17, 2004 | 10:08 PM
Kenny's Avatar
Kenny
Hi,
Definately not a flathead.
What you have is a 300 Inline six. I'll move this over to the Inline six forum, where they may be able to better help you.
Moved from the Flathead forum.
Old Jul 17, 2004 | 10:46 PM
bigbrown84truck's Avatar
bigbrown84truck
forget cleaning the pcv valve, it's a 5 dollar part, just buy a new one along with all the new lines leaving it, you'll spend about 10 dollars, make sure it has the proper breather oil cap as well, not a screw on job with no breather that napa tries to give as the replacement. also when u get the pcv valve make sure you get the right one, do not use the one in the truck now to go off of, it could be the wrong one, go to wal-mart or a parts store and get one and look it up in the book. you shoulda did this stuff before u replaced your valve cover gasket since having too much pressure can blow the valve cover gasket back out. as far as the oil leak you have now, you have to pull the tranny, it sounds like the rear main seal, i have the same problem. if what i mentioned above does not fix your blow by problem you should know that the motor will run forever with blow by, the 300 is all but unkillable, just gotta make sure to change out that crappy nylon timing gear before it craps out or things could get messy.
karras
Escape & Escape Hybrid
Jun 2, 2015 09:57 AM
6.9 BLUES
Apr 2, 2014 12:21 AM
devbravo
Feb 24, 2014 09:16 AM
IDIDieselJohn
13
Nov 22, 2013 11:29 AM
highguy2012
Jul 3, 2012 08:40 PM
