Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Torque value for front bearing hub for 01 XLT 4x4?
Old Jul 8, 2004 | 08:04 PM
gd98tj's Avatar
gd98tj
Question Torque value for front bearing hub for 01 XLT 4x4?
Does anyone have the torque value for the nut that connects the front bearing hub to the CV axle for a 01 4x4 XLT Escape? I may have a bad front bearing caused by the removal of the front rotors (see my thread on BFG Long Trail noise ... posted on 7/8 by gd98tj).
These are typcially around 110 - 130 ft lb.
How about the front hub to front steering knuckle bolts torque setting?
Thanks.
Old Jul 9, 2004 | 08:41 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Wheel hub nut 214 lb-ft.
What do you mean by the hub to steering knuckle? The hub is pressed into the bearing in the steering knuckle.
Old Jul 9, 2004 | 11:07 AM
ove1's Avatar
ove1
I suspect that you have a defective tire rather than a bad bearing. Anyway, here are the torque specs for reinstalling the steering knuckle:
Steering knuckle to strut bolts: 85 ft-lb
Ball joint pinch bolt: 52 ft-lb
Tie rod end: 41 ft-lb
Axle nut: 214 ft-lb
Good luck and let us know what you find.
sickpup2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 25, 2020 04:35 AM
Sixoh
1983 - 2012 Ranger & B-Series
Mar 12, 2011 05:56 PM
FastBlack
Aug 28, 2008 08:54 PM
gd98tj
Jul 16, 2004 11:24 AM
Fordman1962
May 26, 2003 02:07 PM
