my a/c is doing wierd stuff
my a/c cycles quite alot, it blow cold only when the compressor cycles on, the instantlygoes warm as soon as the compressor cycles off, the pressures are also a little high. i have already changed the orifice tube(red one), and ive also changed the receiver-dryer. apparently it had a leak. anyone got any ideas?? parts are expensive!!
I have found that nothing is cheap about A/C repair. I replaced the entire system on my '92 about 8 years ago at a cost of about 1200.00. Not sure what happened to the factory system. It crapped out after 3 1/2 years. That would be 6 months after the warranty was up. Thanks FORD. I let an independant fix it. Best to let a pro mess with the A/C. Sorry I could be no more help.
