my a/c is doing wierd stuff
Old Jun 8, 2004 | 08:10 PM
redygo's Avatar
redygo
my a/c cycles quite alot, it blow cold only when the compressor cycles on, the instantlygoes warm as soon as the compressor cycles off, the pressures are also a little high. i have already changed the orifice tube(red one), and ive also changed the receiver-dryer. apparently it had a leak. anyone got any ideas?? parts are expensive!!
Old Jun 9, 2004 | 08:49 AM
cmoore's Avatar
cmoore
I have found that nothing is cheap about A/C repair. I replaced the entire system on my '92 about 8 years ago at a cost of about 1200.00. Not sure what happened to the factory system. It crapped out after 3 1/2 years. That would be 6 months after the warranty was up. Thanks FORD. I let an independant fix it. Best to let a pro mess with the A/C. Sorry I could be no more help.
Old Jun 9, 2004 | 05:00 PM
taisa899's Avatar
taisa899
have you tried recharging it??
Jim
Old Jun 16, 2004 | 08:02 AM
redygo's Avatar
redygo
ya i have every time i change something i recharge then i recover 'cause it wont work properly
