5.0 rebuild questions
Old May 31, 2004 | 08:11 AM
csnels92's Avatar
csnels92
I looking for the best cam, rocker arm, piston,timing setup and machining combos that will give me the best low end torque. It is a 92 F-150 speed-density roller motor.
Old May 31, 2004 | 10:36 AM
jwtaylor's Avatar
jwtaylor
How much you wanna spend?
I would think for low end your stock intake should be fine, camshaft call comp cams and ask about their extreme energy camshafts they will recommend one to you, they make great low end torque. Piston wise, use what you want to achieve the amount of compression you want. A stock replacement timing chain is fine, unless you wanna get one that allows you to degree the camshaft. For rocker arms I would go roller but use the 1.6 ratio going with a higher lift is useless being your getting a new camshaft that has the required lift built in.
To really gain low end torque, you may consider adding lower gears to your axle(s), possibly a higher stall converter to take advantage of what you have, otherwise you would need ported or different heads and more cubic inches to increase your torque dramatically. Good luck
masterloomis92
Feb 28, 2017 04:25 PM
Jeffs92Bronco
1978 - 1996 Big Bronco
Sep 1, 2016 03:28 PM
'92 Ford
19
Jun 23, 2016 12:04 AM
Herrerag92
May 24, 2012 11:13 PM
oldmcdonald2005
3.0L V6
Aug 19, 2003 01:44 PM
