Best speed rear gear ratio for 1979 f100????
An AOD, if I recall correctly, has a 0.67 overdrive. Pair that with a 4.10 rear gear and it'll have a 2.75 rear gear which is really good for freeway driving. Theoretically, it'll have a high top speed but it'll have to have enough HP to push a Dent with the aero of a barn door more than 120 mph.
Moving on....an AOD first gear is like 2.40. With a 4.10 rear gear, that gives ya 9.85 multiplier which is decent, but not exactly a rocketship although it will help launch out of the box quicker than with a numerically lower rear gear. A better first gear ratio is in the 13s... like a 3.27 first gear and a 4.10 rear rear which equates to 13.4. That's on par with the latest muscle.
Be mindful with a 2.4 and 4.10 cuz stock AODs weren't exactly known for launching a 4,000-4,500 lb behemoth off the line.
Simply put, 4.10's with an overdrive, or 3.50's without an overdrive, would get you down the road. I say 3.50's because they are very common. They make a 3.73 gear for the 9", but you'll more than likely have to build it yourself or find someone that's already done it.
Do the math... Engine RPM Calculator
A 0.67 fourth gear and a 3.90 rear gear results in a final drive ratio of 2.61. A 275/60-15 is about 28 inches tall. At 70 mph, that's right at 2200 RPM and 80 mph it is 2500 RPM.
I would consider a 3.90 if the highways around me are on the flatlands. If you've got rolling hills, ya might be dropping into third alot to maintain your desired speed.
Ya need to factor in your engine's RPM sweet spot... too low and it'll be a dawg... if on the border, then it'll be frequently shifting in and out of 4th.
fdeeptone
15
03-24-2014 06:20 PM
bhardy501
12-19-2010 12:24 AM
Mike W
11-20-2002 07:25 PM
