Identify these C6 controls (pix)
Old May 15, 2004 | 12:16 AM
GeneStoner's Avatar
GeneStoner
I do not have access to my Ford repair manuals righ now, but need to identify each of 3 levers on the side of my SB C6. The actual shifter linkage is a B&M unit with it's proprietary lever/linkage.
http://photos.ar15.com/ImageGallery/...ImageUnq=25272
http://photos.ar15.com/ImageGallery/...ImageUnq=11813
What does each lever do, including the one whose endpiece is off the edge of the pic? Is the little lever with the ball end supposed to move independently of the actual shifter lever?
TIA
GS
Old May 15, 2004 | 09:50 AM
mark a.'s Avatar
mark a.
From the case out: the first one is the factory shift lever. The 2nd one is a after market B&M shifter adapter. The 3rd one is the manual kick down.
Old May 15, 2004 | 05:42 PM
GeneStoner's Avatar
GeneStoner
How far is the manual kickdown lever supposed to move when actuated?
Old May 15, 2004 | 09:02 PM
mark a.'s Avatar
mark a.
Until it stops in the trans, it's adjusted at the carb. Theres an over ride spring on the carb so it cant bind at full throttle if you want to adjust it to come in before full throttle. Push the rod down, pull the throttle wide open and adjust the screw. I keep mine at full throttle, but you can adjust it the way you want it.
Old May 17, 2004 | 02:31 AM
GeneStoner's Avatar
GeneStoner
Got it Mark, thanks.
But I was wondering how far (in actual distance) does the lever actually move before the kickdown is effected? 1/2", 1", more? Less?
Old May 17, 2004 | 11:05 AM
mark a.'s Avatar
mark a.
Around an inch.
