Yes, I have a 4 barrell Holley Carb. that I have not been able to identify. I have checked the Holley sight and it was no help. Here is the information on it.....
2TE - 9510 - CRA
LIST - 9913
1284
That was located on the piece where the choke plate goes as the typical Holleys. I picked up a couple off of Ebay and I identified the first one which came off of a 1974 Heavy Dut 391 but this one I am not sure. The carb. is almost identical but the bores are bigger, I think it might just be a higher flow rating. The smaller one was 600 cfm. This carb. does have a governor on it and a ton of linkage. Can anybody help me?
The first number is missing the first letter. It determines the year. D2=72 E2=82 etc.
I would go to Holley.com and e-mail them with the numbers. They usually respond within 2 working days and can give you specifics of your carb.
