Bronco II Ford Bronco II
Will 33's fit on a 1987 bronco II with not lifts
Old Mar 21, 2004 | 01:23 PM
TylerG's Avatar
TylerG
I need to know if 33's will fit a stock bronco II with no lifts
TYler
Old Mar 21, 2004 | 07:26 PM
mjb1962's Avatar
mjb1962
I have 31x10.5's on my 89 with no lift. The front tires rub the sway bar at full steering lock and the rears contact the outer portion of the wheel wells with the sidewall lugs during rough conditions.
Mark
Old Mar 21, 2004 | 08:24 PM
Bronco 1169's Avatar
Bronco 1169
I have 33x10.5 But the rub up front .
Old Apr 1, 2004 | 12:30 PM
TylerG's Avatar
TylerG
Running boards?
Do you have running boards on your bronco? IF so do the tires rub on them. IF not what do they rub on?
Old Apr 2, 2004 | 10:33 AM
rebocardo's Avatar
rebocardo
No. You need a 3 inch body lift and 31x12.50x15s should fit nice. For 33s, I would just go with a James Duff suspension lift.
Old Apr 17, 2004 | 03:01 PM
TMyers269's Avatar
TMyers269
Hmmmm, now I am confused are you suggesting the body lift or the suspension lift?
Old Apr 17, 2004 | 10:59 PM
jeeph8ter's Avatar
jeeph8ter
If you're putting 33's on I suggest both a 3" suspension lift and 2" body lift but that's if you actually plan to use it off-road. You may want to look into regearing the differentials too. I have 31's with the stock diffs and I have problems with long hills on the highway.
Old Apr 20, 2004 | 10:08 PM
iwannabebig's Avatar
iwannabebig
I have an 84 with 33's, I did a 3 inch body lift and cut the fenders, the only time that my tires rub is at full turn over hard bumps. My truck is solely for mudding and it is absolutely find with the 33's after three inch lift, but you'll have to cut the fenders.
Old Apr 21, 2004 | 08:46 PM
Aggie05's Avatar
Aggie05
33" tires will not fit on broncoII stock
I own a 89 broncoII with a 4" ruff country suspension lift. The biggest tires i could really fit was 31's. 32's might fit but rub under extremem mudding, you need atleast 5 to 6 inch lift for 33's without having to worrying about rubbage. less then 5inchs of lift and you will have to cut the fenders.
Old Apr 29, 2004 | 12:35 AM
CherryColaholic's Avatar
CherryColaholic
my 89 with 2 inch lift in rear only has 31x10.5's.. they only rub when i jump it and dont land on all fours. or when you turn the steering wheel all the way it rubs a little then too. So i would say 31's are the biggest with no lift.
Tim Shearer
Bronco II
Mar 23, 2022 08:09 AM
Tim Shearer
1978 - 1996 Big Bronco
Jun 15, 2016 11:16 AM
Hardcase_Ford
Bronco II
Feb 1, 2010 06:46 PM
landon460
Apr 6, 2009 09:21 PM
evilhorde
Mar 4, 2005 02:53 PM
