What is a "thermistor"?
I'm trying to turn off the CEL on my 95 Ranger. Getting a 1443 code-purge valve open. My purge valve seems to be stuck closed. It holds about 25" vacuum and won't release with the key on. There is another relay (dealer called it a thermistor) in the system. The hose comes from the manifold to the thermistor, to the purge valve, to the charcoal canister. All I can think is that it must be some sort of voltage regulator that varies a valve with temperature. Anybody know? The Haynes manual doesn't say anything about it. Thanks for any help. I ordered both parts from the dealer and will change them soon, but really am curious.
Maybe this thread from the FTE 3.0L V6 Forum will help you out a little:
Evaporative Emissions Control Valve (EVAP)
Vista703
08-26-2015 02:10 PM
