Startup died after year's storage
Old 02-20-2004, 12:21 PM
89FRgr1's Avatar
89FRgr1
89FRgr1 is offline
original ownr 89 ranger 2.9L 6cyl suprcab. 70K only.
stored outside in the great but moist Northwest.
new battery. started up immediately, ran great, then sputtered out in about 30 sec. Won't start again, or even "catch" briefly. 24 hours wait no help/ Tank 75% full.
Suggestions? Water in line? (if so, how remove?)
TIA!
Old 02-20-2004, 01:17 PM
jokieman31's Avatar
jokieman31
jokieman31 is offline
If you didn't use some kind of fuel stabilizer, replace it. Change ALL the fluids, and give it another try.
Old 02-20-2004, 02:32 PM
Ken00's Avatar
Ken00
Ken00 is offline
Welcome FTE!!!!
Do you have spark and fuel pressure?
Old 02-20-2004, 04:26 PM
89FRgr1's Avatar
89FRgr1
89FRgr1 is offline
Spark OK. F.Pressure unsure. Will check. And replace fuel if nec. (WTH do i do w 12G old gas?!)
TX
89FRgr
Old 02-20-2004, 04:42 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
One quick & simple thing that you can try is to remove the air tube from the throttle body & see if it runs. If it does run, pull the air filter out & see what's clogging up the works.
Old 02-20-2004, 08:01 PM
Dealford's Avatar
Dealford
Dealford is offline
Also, while you have the air intake tube off, give it a VERY LITTLE shot of starting fluid and see if it catches at all.
Take all the old gas out, change the fuel filter, add gasline antifreeze to remove any remaining water, and put in fresh gas.
Old 02-21-2004, 12:31 AM
Leo_T's Avatar
Leo_T
Leo_T is offline
Hi 89,
There's a product called PRI that claims to restore old gas
http://www.priproducts.com. I've heard from outdoor power equip people that it's pretty good stuff.
