Mustang fuel injection on truck
Old Feb 12, 2004 | 06:54 AM
original67's Avatar
original67
I am wondering if fuelinjection off of a 1993 mustang with a 5.0 HO will fit on a 1990 ford truck with 5.0 EFI
Old Feb 12, 2004 | 07:30 AM
EPNCSU2006's Avatar
EPNCSU2006
What part of the fuel injection? The wiring harness will need to be modified to plug into the existing truck harness, or the truck harness needs to be updated with the correct parts and pin locations for the mustang computer. You will need a mass air meter, and an injector wiring harness for sure. If you are talking about the intake manifold, yes it will bolt to the engine, but it will be difficult (not impossible by any means) to get the throttle linkage, etc. working correctly. You'll also lose a lot of low end torque with the mustang intake manifold.
Old Feb 12, 2004 | 01:26 PM
original67's Avatar
original67
I am thinking of the upper intake and the fuel injectors
Old Feb 12, 2004 | 04:26 PM
EPNCSU2006's Avatar
EPNCSU2006
The fuel injectors are exactly the same, and the Mustang upper will not mate with the truck lower. You'd have to run the upper and lower from the Mustang to be able to use it. The truck intake flows more, so I've heard, and it makes sense, the ports are much larger. It is also better for low end torque with longer runners.
Old Feb 12, 2004 | 09:34 PM
original67's Avatar
original67
Allright thanks for the info
jade79
Jul 26, 2016 08:49 PM
GHeTTo JOe
EcoBoost (all engine sizes)
Apr 20, 2013 12:17 PM
extcab 95flareside
Nite, Nascar & Other Limited Edition Ford Trucks
Sep 27, 2012 09:47 PM
9.ford.5
41
Feb 18, 2010 12:10 AM
kellar
Computer Chips & Tuners
Oct 11, 2006 05:53 PM
