Oh man this is getting annoying
Old Feb 12, 2004 | 06:34 AM
cliffordthetruck's Avatar
cliffordthetruck
Ok boys here it is,
1991 e-350 351w efi. Idles rough, intermitent loss of power and occasionally dies right out. I can start it again right away but it will continue to run irregularly.
To deal with this problem I have replaced
ignition coil
tfi module
had tank cleaned
new fuel filters
new EGR
I would like to believe that it is a problem with fuel delivery but I just don't know enough about the pitfalls of the efi systems to check anything. From what I have read, I beginning to think of problems potentially with the
fuel pressure due to pump or fuel pressure regulator
fuel injectors or mix
Anyway, if any one could list some testing proceedures that I could do or could have done I would appreciate the guidance.
Many thanks
Old Feb 12, 2004 | 07:33 AM
EPNCSU2006's Avatar
EPNCSU2006
Have you pulled the codes? That would be a good place to start from. Go here: http://fordfuelinjection.com/index.htm and go down on the left and click on "Getting Codes." EFI systems are pretty good about diagnosing themselves if there is something wrong electrically. I'd also clean the idle air control solonoid to make sure it is not stuck.
Old Feb 12, 2004 | 09:09 AM
f100guy's Avatar
f100guy
yeah the car doctor on the radio said it was carbon in the mass air flow sensor and related sensors. clean them and try. i had a truck like that. it was a 90 or 91 with maf 5.0 it had the dual intake mass air flow sensor on it. i just lived with it.
Old Feb 12, 2004 | 12:29 PM
cliffordthetruck
I pulled the codes and got 33 and 41. Where is the mass air flow sensor.
I also read a possible problem from the van forum which led me to believe that it could be the temperature sensor. Cause the problem occurs only after a little driving.
Old Feb 12, 2004 | 12:56 PM
f100guy's Avatar
f100guy
code 41 on my 95 v6 mustang was an o2 sensor code. but i think they may be different. sorry i meant the throttle body instead of the maf sensor.my truck had the mass air efi on it i don't know much about the other efi or what years and vehicles it was on but if you engine has the 2 piece intake manifold it it a mass air efi. the throttle body is what the air filter intake hose connects to. clean it good but not with carb cleaner. you need something specifically for that
Old Feb 12, 2004 | 02:22 PM
cliffordthetruck
I have cleaned the throttle body and idle air bypass. 41 is o2 sensor on the 351w as well. Maybe that could be another source.
Old Feb 12, 2004 | 04:23 PM
EPNCSU2006's Avatar
EPNCSU2006
All EFI's had two piece intake manifolds. There isn't a mass air meter on your '88 so that's one less thing to look for. Mass air computers didn't start appearing in trucks until very few in '94 and '95 and all of them (all but the 460) in '96. 33 is EGR valve opening not detected. There are several tests you can perform to pinpoint the exact cause of this code. If you don't have a Haynes manual, I'd definitely pick one of those up - it has all the tests in there. 41 is an O2 sensor code, switching not detected, always lean. That means there is either a fault in the wiring for the O2 sensor, or the O2 sensor is bad. I'd go through the wiring checks to be sure the wiring is good.
Old Feb 12, 2004 | 04:36 PM
hdgapeach's Avatar
hdgapeach
Same situation, different truck. Mine turned out to be the O2 sensor itself and the associated wiring at the attaching point. All this was caused by an oil leak that had saturated the wiring. Worth a check.
Old Feb 12, 2004 | 07:27 PM
f100guy's Avatar
f100guy
yeah EPN told me that somebody may have done a mass air conversion before i got it. i thought the throttle body injection had an intake manifold that was simular to a carbed manifold and the throttle body looks simular to a carb. but anyway my 90 had one of those dual intake throttle bodies. the truck was bought new from fy great grampa then sold to my uncle and finally givien to me without knowing too much about it's history
Old Feb 12, 2004 | 09:21 PM
carpe_diem's Avatar
carpe_diem
> Idles rough,
I had the same thing, could not idle, and it was Idle Air Control Motor. Very simple to replace. I wanted OEM part, but used something from Napa parts and it worked great.
I also thought it was TPS (sensor), but it wasn't.
I didn't have loss of power, which shows it something other than above.
IMO, O2 sensor would not cause either condition, just make it run rich, but not really loose that much power and it certainly would not make it die.
Old Feb 13, 2004 | 05:36 AM
duff man's Avatar
duff man
i would try a fuel pressure gauge. it should crank up rather fast and hold for awhile. i think pressure should be around 38-42psi on those but could be mistaken. look in book. what is o2 sensor sayin is wrong lean/rich? if injectors are dirty it usally isnt intermident. if fuel pressure drops fast on gauge and dies its probally the pressure release in the pump. a lean condintion can also be caused by a vacume leak or bad map sensor. a bad iac valve could cause same thing try cleaning the pintle and port it may help but they usally require replacement.
let us know
Old Feb 13, 2004 | 08:05 AM
cliffordthetruck
Who, what, when, where, and why is an iac valve.
I haven't been able to find a fuel pressure gauge. Is there another gauge that I can use?
Old Feb 13, 2004 | 08:17 AM
luckild's Avatar
luckild
IAC stands for IDLE AIR CONTROL. IT'S LOCATED ON THE THROTTLE BODY AND REGULATES AIR BYPASS IN IDLE CIRCUIT. PICK UP A NEW GASKET, REMOVE VALVE AND CLEAN THE HECK OUT OF IT. LOOKING TO REMOVE ANY DIRT OR CARBON BUILD UP. INSTALL AND TEST. GOOD LUCK.
Old Feb 13, 2004 | 11:14 AM
f100guy's Avatar
f100guy
running rich will make your motor run rough and lose power.
my 95 stang started running rich on 1 bank 1 month ago and that was because i had a bad bottom intake gasket. it started sucking unmetered air in which told the computer to richen the mixture up on that side. i have true duals so i had all kinds of black smoke puffing out one pipe. and it had bad acceleration until the plug got hot enough to even fire it off better. it smelled bad and i was getting fuel in my oil and bad gas mileage. smell your oil to see if it smells like gas. if it does then change it and that tells you that your engine is flooding.
Old Feb 13, 2004 | 11:49 PM
duff man's Avatar
duff man
you can pick up a high pressure fuel gauge at any auto parts place autozone,napa or even sears.
it hooks to a schrader valve on the supply line by the manifold.
