FE 60 amp Alternator Rebuild
Old Jan 2, 2004 | 10:12 AM
75SPRCAB's Avatar
75SPRCAB
Question FE 60 amp Alternator Rebuild
I am considering trying one of those 80 or 105 amp upgrade its for the OEM alternator. Does anyone have any experience with these, good or bad?
Old Jan 2, 2004 | 03:41 PM
biz4two's Avatar
biz4two
Good question. I do not have any experience with it, but am interesed. If you find anything out...please post the results.
Old Jan 2, 2004 | 03:54 PM
proeliator's Avatar
proeliator
I did that. Easy enough to do...I went with the 105 upgrade. Worked good for three months untill it burned up. Frustrated, I just went and bought the 2g 90 alt. for the 70s era lincolns...modified my mounting brackets and alt plug and its worked great ever since. I wouldn't go with a kit again.
Old Jan 5, 2004 | 02:22 PM
Steve_Uzi's Avatar
Steve_Uzi
Proeliator,
I am curious as to why it Burned up? Did you change the primary charging wire to 4 guage?
Old Jan 5, 2004 | 03:59 PM
biz4two's Avatar
biz4two
Originally posted by Steve_Uzi
Proeliator,
4 gauge? Is that something that should be done? I can't remember of the top of my head what gauge wire I used...but I am sure it was not a 4...maybe a number 8. I installed a PowerMaster 90amp one wire hookup on my truck and it left me stranded...killing the battery. Didn't even last a summer season. Now I am back to the 60-61amp...
Old Jan 5, 2004 | 04:04 PM
Steve_Uzi's Avatar
Steve_Uzi
From what I have been reading... when installing a 3G 130 amp alternater you need to change the charging wire (the one going from the alternator to the soleniod) to 4 Guage.
Old Jan 5, 2004 | 04:55 PM
Franklin2's Avatar
Franklin2
Makes sense to me. And you would need all of your high current loads tied to where the 4 guage ties(the starter relay or an aux fuse box on the fender). What would be the purpose of a higher amp alt without upgrading the wiring?
Old Jan 5, 2004 | 05:29 PM
Steve_Uzi's Avatar
Steve_Uzi
Right! I am going to wire a 175Amp ANL fuze inline with the Charging wire incase of a surge or a short it will blow, rather than toast other wiring..
The reason I am doing the upgrade to my 84 Bronco is because I believe that the stock alternator is only a whimpy 60A! maybe 75A. I want to install a decent (not craZY) stereo system with about 500watts of RMS power. I will also be running 4ga wire directly to the battery to power the 2 amps. I will be installing a 100Amp ANL fuze inline with the Amp wire.
Old Jan 5, 2004 | 07:14 PM
Mike W's Avatar
Mike W
I think that under a constant load, you can only pull maybe half of the alternator's rating in amps.
Old Jan 5, 2004 | 10:01 PM
biz4two's Avatar
biz4two
Well if there is to be a next time upgrading from the 60amp to a nice 90 +...I'll go with a 4ga.
Sure do wish the instructions mentioned that! Of course it could be that PowerMaster is "NOT" all that in quality.
Old Oct 26, 2006 | 04:09 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
3G 95 amp Vs. 120 amp alternator
I ran accross a chart that indicated that the 120 amp alternator might be a better 3G upgrade. The 95 amp alternator did not begin pushing amps until a much higher RPM. I'm thinking that trucks need the current at low rev's, where we spend most of our time.
Verification welcome.
Kevin
Old Oct 26, 2006 | 04:46 PM
Franklin2's Avatar
Franklin2
No alternator does very well at low rpm's. Some may do better than others, but I have no data on that.
I set the idle speed up on my truck a little bit in the winter for my snowplow. I only have the stock 60 amp(I believe that was stock) and it does very well with the plow. If I don't adjust the idle up, it won't hardley pick the plow up off the ground.
Old Oct 26, 2006 | 09:59 PM
1972-34ton's Avatar
1972-34ton
Correction: That should be a 130 amp alternator, for the 3rd Generation type.
