22 F550 rear differential problems
Old Yesterday | 07:50 AM
lynkage's Avatar
lynkage
Has anyone here had or heard of a problem with the machining of the rear differential housing eating up bearings and the track loc?
Specifically, the pinion bearing seat? I had one other person who said that their work truck, a 22 550 as well, had a rear pinion issue and found the case was machined improperly for the bearing seat and had to get a new axle housing to fix the problem.
Mine has had a vibration since new and now has 48k on it. I have had it to the local dealer (I live in a small town) who is absolutely unhelpful, telling me that I needed to buy a pallet of concrete before he would even look at that problem.
I have replaced and balanced the tires/had the wheels checked for round at a medium and heavy duty truck tire shop. I still had the problem. I finally took it to a neighboring city to a heavy duty truck drivetrain specialist who found the driveline was slightly unbalanced and the carrier bearing was completely gone. I drove it and found the vibration was slightly better but still there. They drained the diff and found the oil looked like mercury and took apart the diff. Bearings and track loc were toast. I have a Ford warranty but wonder how this will work. The truck is still in the shop with an estimated total of $4k in repairs.
If there was a housing issue, I want to inform them before it is reassembled and eventually have the same issue again.
Anyone have any input?
Thanks,
Shane
Old Yesterday | 02:25 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Following, with some skin in the game, not having any 2022 F-550s, but having similar 2019, 2021, & 2023 F-550s, without any of the drivers reporting such issues (not that the drivers would notice or care though).
You mentioned having a "Ford warranty." Is this an "extended" warranty through what is now called Ford Protect?
I'm guessing that the Ford dealer was wanting some weight on your chassis, not specifically a pallet of concrete, but at least 2,800 more pounds of weight (assuming your steel skirted flat bed is 1,200 lbs) in order to evaluate the pinion angle at optimal designed operational ride height.
After Dana and Eaton parted ways, Dana repurposed their old trademarked name Trac-Lok (formerly describing a friction disc based limited slip in the 1970's and '80's) into describing Dana's me-too copycat version of Eaton's Detroit TrueTrac helical gear based limited slip, which Dana/Spicer introduced in 2020 as Trac-Lok.
Dana's re-use of the name Trac-Lok to describe two entirely different limited slip systems is confusing, so I just wanted to check in with you to confirm that the Trac-Lok components that the independent shop claims are trashed in your strewn apart rear differential are indeed a helical gear based system, and not a friction disc set up.
Old Yesterday | 05:28 PM
lynkage's Avatar
lynkage
Thanks for the reply.
I do not know what limited slip components are in the differential, however, I can certainly ask. They did mention that the unit was 60 lbs and they could not get it overnighted so it would be a few days before it arrived. I understand this rear end to be a Dana M300. It has 4:88 gears
The GM of the dealer said I needed to buy the weight before he would test it, which is ridiculous because it did it loaded or unloaded. If those were his requirements, then it should be up to them to provide said weight.
As far as the warranty, it was the Ford extended warranty out until 175k. I do not remember the name of it, but it wasn't called Ford Protect when I bought it in 22 but it was their premium product at the time.
I did not buy the truck from them; I bought it from Rush medium duty truck center in Denver.
Old Yesterday | 06:34 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
If you have 4.88, then you must have a gasoline engine.
As such, your driveline is spinning faster at all times, in all situations, which could be useful to keep in mind, when comparing what you are experiencing with others.
In 2001, Ford changed a component in their automatic transmission of that era, and the design problem with that component manifested in higher RPM gasoline engine equipped trucks, but did not always manifest in lower rpm diesel equipped trucks, even though the same problematic component existed in the transmissions of both trucks. Ford initially issued a stop sale and recalled the gas trucks, while letting the diesel owners twist in the wind without resolution until their warranties expired.
I am not saying that this is the case here. I'm just saying that as you seek resonant experiences from other truck owners who you find have had similar concerns (as you mentioned in Post #1), keep in mind what engine they have, as that effects the amounting of spinning the driveline has to do per mile, which effects wear rate of the carrier bearing and parts internal to the differential.
Does the fine print of your extended warranty agreement have any pre-authorization requirements for non dealership service procedures?
Old Yesterday | 08:34 PM
lynkage's Avatar
lynkage
No, it's a 6.7. If you look at the door in my avatar, you can see the powerstroke emblem. 2022 last year that the 4:88 with a diesel was an option. I didn't have a choice back then. This is what the dealer had. It was for Earthromer but I bought it before they did.
No idea about the pre auth, it would not surprise me if they try to weasel out of paying, it's what most large corporations do now days.
Old Yesterday | 11:21 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
For a while there Rush had about 25 black crew cab 84" CA Lariat F-550s on their lot at one time, all for sale, but all originally destined for one or more of those fancy truck upfitters in the Colorado area.
2bitsamile
Jul 23, 2014 07:39 AM
Krafty
2004 - 2008 F150
May 23, 2014 11:51 PM
TeeK75062
Jan 17, 2011 06:28 PM
BWOP
Modular V10 (6.8l)
Jul 10, 2007 05:20 PM
wresleu
1983 - 2012 Ranger & B-Series
13
Jan 13, 2005 07:27 AM
