Looking for headers, that will work with 4x4,
Old May 31, 2026 | 01:50 PM
PaulCf250,5.8,89's Avatar
PaulCf250,5.8,89
4wd Low
Hi guys, I currently have my 351 Windsor on an engine stand and I'm doing a gasket overhaul and seals as well as some other things. I am considering putting a pair of headers on the truck, I have a 1989 Ford f250 4x4, 351 Windsor with a C6 , and a Dana 50 ttb in the front,
I'm not looking to break the bank on these, I believe I need shorty headers, if anybody has ran headers on these trucks before, any advice would be appreciated. Thanks in advance.
Old May 31, 2026 | 07:34 PM
whisler's Avatar
whisler
I have almost the identical truck and setup and used JBA shorties. Happy with mine.
Old May 31, 2026 | 07:43 PM
90project5.0's Avatar
90project5.0
I use Hedman shorties. Only time you need “specific” headers would be long tubes. Shorties will bolt straight up to Y pipe.
As long as they are for a 351, they will work. Delete the EGR tube and you can use 302 headers.
Old Jun 1, 2026 | 09:29 AM
PaulCf250,5.8,89
4wd Low
Thanks
Thanks guys, I will look into it.
Old Jun 3, 2026 | 11:45 AM
torq'ta 5 8's Avatar
torq'ta 5 8
My BBK's haven't leaked since install 5-7yrs, put the stage 8 locks on them, and your done
Old Jun 3, 2026 | 11:59 AM
90project5.0
Might I suggest header gaskets, I kept getting leaks until I bought a set of remflex gaskets. Solved that problem!
Old Jun 3, 2026 | 04:33 PM
cougrrcj's Avatar
cougrrcj
My buddy did the same (JBA shorties) with his now-393W '95 F250XL/standard cab, 8' bed 5.8L auto 4x4.
Old Jun 3, 2026 | 05:12 PM
cougrrcj's Avatar
cougrrcj
302 headers are NOT the same as 5.8L headers. The factory Y-pipe WILL fit 5.8L shorties, but 5.0 shortie exits will be too far apart and an inch higher, making pipe from there back more difficult fitting around shift linkage, 4x4 driveshaft on the drivers side, and may hit the AC plenum on the passenger side. The 5.8 shorties are routed tighter to the engine block and extend farther down.
Old Jun 3, 2026 | 05:29 PM
90project5.0
My mistake! I could have swore I read threads on people using them if they deleted the EGR. If they are longer, then in theory 302s could use a 351 y pipe with a little finagling.
Old Jun 3, 2026 | 07:30 PM
cougrrcj's Avatar
cougrrcj
On 351W-swapped Fox Mustnags and such, the 351W-swap shorty headers tucked in and down a bit farther so they exited at the same location as the 5.0 manifolds into the H-pipe, so it actually bolted right up to the stock exhaust! waaaaaay back in 2006, I used 351W-swap Mustang shorties on the 393W in my '89 Crown Vic - I had initially tried 5.0 shorties, but as I stated above, the 5.0s stayed 'high' and were in proximity to my A/C plenum and melted it! The 351W-swap headers tucked in closer to the engine block, and from there I used a 2-1/2" 'off-road' 5.0 Mustang H-pipe...
Old Jun 4, 2026 | 08:15 AM
dremtofford's Avatar
dremtofford
this is good to know. one of the last things i need to know about headers for my 88 f 150 302 extended cab 4x4.
Old Jun 5, 2026 | 07:24 PM
'89F2urd's Avatar
'89F2urd
You need to be willing to bend the collector on the drivers side away from the 4x4 components. I have installed enough long tubes on this vintage truck to know that even the long tubes that are infamous for clearing 4x4 components still end up in the 4x4 components (albeit, the brands notorious for clearing I have also installed with no problems in other builds). Be prepared to torch the collector to get it into a desirable place before you build a y-pipe or send it to the exhaust shop. The long tubes are well worth even the most trouble.
Tim J Miller
Feb 15, 2012 10:07 PM
Poulsom
May 22, 2005 03:32 PM
Phessor
Jun 23, 2004 10:51 PM
77' f-100 ranger xlt
Dec 8, 2003 12:40 AM
BlueTorpedo85
Exhaust Systems
Jan 29, 2003 10:47 AM
