almost anything will work if you want to make it. i had a 60's Cadillac leather power seat in my 88 for around 4 years until i found a set of Bronco buckets.
all i had to do was make some mounting bracket adapters.
What cab? Just looking for a replacement or specific look?
Regular cab. A normal bench is fine, but its more about what I can find, but again, I'm not sure what I can use. As cool as a Caddillac seat is, fabrication isn't a realistic option at the time.
Huge hole in the middle where the wires all broke. Good to know about the single crew cab seat. Thank you.
If you’re up for the task, you can rebuild it yourself. Some ideas below.
Comes in all different sizes, just measure yours. One website, all sorts of colors and styles Basic foam replacement for bottom. You can use sections of old bottom to build up back areas!
