10R100 Checking Transmission Fluid Level
Old May 21, 2026 | 05:42 PM
exploringcarolina's Avatar
exploringcarolina
6th Gear
Been searching how to check transmission fluid level on a 2024 F-350 6.8L 10R100 transmission.
If I level the truck and remove this plug on the driver's side of the transmission with transmission temperature between 206F to 215F and fluid drips out, is the fluid level correct?
Thanks,
Old May 21, 2026 | 06:34 PM
SMSTX's Avatar
SMSTX
Yes, that's exactly right
Old May 21, 2026 | 07:13 PM
exploringcarolina
6th Gear
Thanks!
Old May 22, 2026 | 06:50 AM
golfnujetsfan's Avatar
golfnujetsfan
Question
engine running or shut off? some manufacturers level check is with fluid circulating. thanks in advance for any responses
Old May 22, 2026 | 07:40 AM
saratoga2011's Avatar
saratoga2011
Running in park.
Old May 22, 2026 | 05:06 PM
Timujin's Avatar
Timujin
Did this. Performed about 4 power brakes to get trans fluid temps up. Trans was overfilled. I reinstalled the plug after ATF started trickling out.
10R100 fluid check
tkrupa1
2009 - 2014 F150
16
Jun 2, 2025 02:37 PM
accent2010
Escape & Escape Hybrid
Jul 9, 2024 10:17 PM
Buster Joe Baker
2004 - 2008 F150
Jun 2, 2024 08:53 PM
96DRW
Jul 1, 2012 10:01 PM
