Can I really fit 37s with leveling kit?
Old May 19, 2026 | 05:48 AM
JWCH2290's Avatar
JWCH2290
1st Gear
Hey guys. I’m new here so forgive me if this is repetitive.
I'm looking to put a leveling kit on my 2024 F-350 King Ranch diesel. My guy at the shop says it will fit 37s with the 2” leveling kit. He recommends 11.50 and says they won’t scrub but the 12.50 will.
planning on keeping the stock wheels.
Anybody got experience with this setup? Pictures would be appreciated.
thanks!
Old May 19, 2026 | 05:56 AM
Midwest87's Avatar
Midwest87
Maybe. Maybe not.
But 12.5 is mo better. Use proper offset wheels that keep the tires tucked in. +18mm will do.
Old May 19, 2026 | 11:14 AM
Rwhjr's Avatar
Rwhjr
The 23+ trucks (and probably older ones too but I can’t confirm) can easily fit 37s with a level kit.
I’ve done it with 20x10s that had a negative offset and now it’s running 18x9 methods and a 37x13.50 (much better look and fit).
There’s no rubbing regardless of the position of the suspension and steering wheel.
But I will say when it had the negative offset wheels I had to cut a small notch in the little plastic piece/edge guard on the front wheel well. With the 18x9s it wouldn’t have been necessary.
The only other thing I did was a tremor size rear block and airbags and it sits perfect no matter the load. Couldn’t ask for more I think the truck looks great and still functions perfectly with this setup!
Old May 20, 2026 | 09:35 AM
CBEllis's Avatar
CBEllis
Here’s a pic or two with my BDS level. It raised the front 2 3/8” and I’ve got 37 x 12.50’s on stock 20’s, no spacers behind the wheels. They fit perfectly. No rubbing, even off-road articulating. I’m very happy with the setup. I’m planning to add an S&B swaybar drop kit, just to realign the end links and push it forward, just for me.
F-250 Super Duty
20
Feb 17, 2009 06:44 PM
Justastrokin'08
Apr 15, 2008 08:26 PM
riored4v
2004 - 2008 F150
Oct 24, 2007 10:06 AM
chewnit
2004 - 2008 F150
Feb 26, 2007 04:46 PM
SierraClubS
Feb 28, 2004 03:51 PM
