Forscan Warning - 2026 Lariat
Old May 14, 2026 | 07:54 PM
Texas78028's Avatar
Texas78028
Brand new F350 Lariat premium package. I plugged in my laptop and was greeted with this message. (see pic) I used the same laptop and software on my 2024 XLT 613A and it worked just fine.
I sure hope Ford hasn't locked out Forscan users .... going to suck if I can't enable Bambi mode.
Old May 14, 2026 | 08:09 PM
travlnman's Avatar
travlnman
Works fine on my '26 XLT....not sure what would cause this??
Old May 14, 2026 | 08:37 PM
Midwest87's Avatar
Midwest87
Bambi mode suks anyways.
Try rebooting everything. Maybe load an update if forescan even has any. Tons of my apps give me a fault when connected to an engine, that clears when I close the app.
Old May 14, 2026 | 08:55 PM
Texas78028's Avatar
Texas78028
Anyone know where the physical PCM is located? I'm wondering if there may be a part number printed on it.
I'm taking it into the dealer tomorrow. I'll ask around.
Old May 14, 2026 | 09:29 PM
Tsax6010's Avatar
Tsax6010
Make sure you have downloaded the latest version available. New model years often require updates to recognize the vehicle. Your version that worked with your 2024 will likely not know what a 2026 is.
Old May 15, 2026 | 05:06 AM
Ford6.7ski's Avatar
Ford6.7ski
Trailering
F350 Lariat 6.7 ho Shortbed
I just had a shop use Forscan to program tank info for an upgraded larger sb 60 gallon tank from a factory 26 gallon tank and it works. DTE shows larger quantity and the gauge goes down.
Appears the info is for a 48 gallon tank which I think is the largest option that should appear on Forscan since that is the largest factory available tank.
Old May 15, 2026 | 05:20 AM
Tsax6010's Avatar
Tsax6010
Correct. 48 is the largest value the truck will calculate on. S&B has a gateway module intercept recalibration device that will correct values to their actual tank size too
https://sbfilters.com/products/2023-...libration-tool
Old May 15, 2026 | 05:54 AM
Ford6.7ski's Avatar
Ford6.7ski
Trailering
That is for the powertrain control module on the 7.3.
Old May 15, 2026 | 06:10 AM
Poncho450's Avatar
Poncho450
Yes. I hadn't used FORScan in several months and I had to update it for my most recent use on a 2023.
Old May 15, 2026 | 09:03 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
@Texas78028
what version of forscan are you using
ZooDad
Old May 15, 2026 | 09:15 AM
7.3TreeFiddy's Avatar
7.3TreeFiddy
I bought a 2026 Lariat a month ago and downloaded the latest version of Forscan and didnt have any issues.
Old May 18, 2026 | 11:57 AM
Texas78028's Avatar
Texas78028
Originally Posted by ZooDad
@Texas78028
ZooDad
I was running v2.3.58 ... I updated to v2.3.71 and it worked for me.
Bambi mode enabled... Thanks!!
Member No. 1
Apr 16, 2024 07:22 PM
Bananasfoster
Apr 17, 2021 02:07 PM
st1nn3tt
Nov 3, 2018 12:50 PM
madcap78
Sep 29, 2017 07:16 AM
Furian
Jan 13, 2011 05:08 AM
