Gas tank skid plate (2005, 6.8 V10)
Old May 14, 2026 | 02:15 PM
sgc2c's Avatar
sgc2c
Is the skid plate (or whatever it's called) that holds up the gas tank in the 6.8 for my 2005 still made new by anyone?
Are the bolts made anywhere and are they anything special or can I get those most places?
It's all rusted like no one's business up there.
Old May 14, 2026 | 02:59 PM
01__Excursion's Avatar
01__Excursion
Gas tank tub, and bolts are the same for all years, it's a discontinued item from Ford and is probably only found on Ebay, or in junkyards.
Old May 15, 2026 | 04:29 AM
Packard42's Avatar
Packard42
Best bet is a junk yard
Not aware of any aftermarket new parts and Ford does not make a lot of new parts for the Excursion. Your best bet is a junk yard. I chose to get a used 44 gal. tank which came with a skid plate a couple years ago. Was a good deal. Had the tank cleaned, replaced fuel pump and rubber hoses. My original skid plate was in good shape so I used that one.
Old May 15, 2026 | 08:16 AM
sgc2c's Avatar
sgc2c
Thank you.
I’ve got two follow-up questions:
  • Is it difficult to separate the tank from the skid plate? I’ve got a guy who is excellent at rust removal who I might want to unleash on these parts and the surrounding area.
  • While I’m replacing the fuel pump itself should I (“may as well” as they say) replace the whole sending unit and that sock-filter thing also? (Whole assembly).
Old May 15, 2026 | 09:27 AM
hammondpipe's Avatar
hammondpipe
I did this replacement a few months ago with a floor jack at my home. No, the straps that hold the skid and tank together can be cut without too much difficulty. I used a pair of tin snips. The tank and skid can remount without replacing the straps. My old plastic tank was fine, but the skid was rusted out beyond repair. My replacement skid came with the tank. I opted to separate the 'new' tank and skid, repainted interior and exterior of the skid, and fluid filmed everything before putting it back up.
My other excursion, V10, had the in tank fuel pump go out at 260,000 miles. I'd probably go ahead and replace now instead of having to drop the tank at a future date again.
Old May 15, 2026 | 05:06 PM
sgc2c's Avatar
sgc2c
hammondpipe, where’d you get a new skid plate?
Old May 16, 2026 | 07:28 AM
Packard42's Avatar
Packard42
I agree with Hammondpipe, the straps holding the tank to skid plate were plastic on mine. I replaced with nylon adjustable straps I got from Harbor Freight. I replaced the whole pump/sending unit with a Delco. The warrantee requires you have the tank cleaned. I paid a radiator shop to do it. 44 Gal. plastic tank was fine otherwise. When they installed new/ clean tank and skid plate, I also replaced several rubber hoses and the metal filler neck along with the rubber connecting boot/hose. My original situation at 247K was gas overflowing onto the ground if I filled the tank all the way. Now, I should never have to deal with tank issues again.
Old May 18, 2026 | 09:29 AM
hammondpipe
I found one on the internet at a salvage yard. Verified the rust was not too bad and had it shipped. I believe it cost me under $600 total. Used a grinder and wire wheel on the end of a drill to knock off and smooth out as best I could, the used Rustoleum primer and paint. Did the same to the rear undercarriage, frame, filler neck, and hitch while I had easy access, and then fluid filmed everything.
I took the old filler hoses to NAPA and replaced those as well. New worm clamps. The hoses aren't going to be pre-shaped like what came off, but I made them work ok.
Worst part was tightening the four bolts back up for the skid. I used some blue loctite on them. One kept trying to cross thread. I bought a spare set of bolt hardware off *Bay in case the old ones didn't clean up.
Old May 18, 2026 | 09:43 AM
sgc2c's Avatar
sgc2c
Thanks, hammondpipe.
What size are those 4 bolts?
I think I might just replace them outright.
Old May 18, 2026 | 10:30 AM
hammondpipe
Honestly, not sure on the size. If I were going to just replace the bolts and not the 'retaining clip/nut' they screw into, I'd take one off to the hardware store and try to match it.
Here's another thread for reference:
https://www.ford-trucks.com/forums/1...olts-nuts.html
Old May 22, 2026 | 07:27 PM
unleashd's Avatar
unleashd
Not sure of your location. FWIW, It took me a few months, but I did find a replacement from a guy that was parting out an Excursion, about an hour away from me. Out here in the NE and Mid-atlantic, finding a decent/good replacement part that is not rusted is tough. I found many places down south in my search, but the shipping cost alone was pretty prohibitive 'cos that skid plate is quite heavy to ship.
samsdad02
Jan 6, 2024 09:51 AM
WTF250
Jun 26, 2023 07:23 AM
murph1
2009 - 2014 F150
Sep 28, 2012 04:14 AM
Aussie 53
Feb 14, 2008 07:10 AM
