I have a 2008 F150 5.4 flex. I recently had cylinder 5 issues. Turned out there is a wiring issue. On cylinder 5 coil harness pins, when performing a continuity the ground and control wires so continuity (not good).
I have traced it out as far as I can find info for. I am looking for wiring pin out on c139. The 16 pin breakout connector off the, I believe is C175E....
I have traced the ground (green/red) from the coil to the harness. However the control wire on cylinder 5 (green/yellow) is also tracing back to, I believe pin 16. Which none of the other cylinders are doing. Any advice on tracing the short further would be appreciated.
