Wiring Issues
Old Oct 6, 2017 | 07:41 AM
Mark Twain's Avatar
Mark Twain
Wiring Issues
Hey all, I've got a 1993 F250 with the 5.8L 351W. I'm looking for a pinout diagram of the 42 pin bulkhead that connects the fuel injector wiring harness to the main engine wiring harness - the male and female ends.
Old Oct 6, 2017 | 09:06 AM
subford's Avatar
subford
I do not know of one for a 1993 but the 1994 C101 should be close if not the same connector.
Old Oct 6, 2017 | 09:31 AM
Mark Twain's Avatar
Mark Twain
I'm not sure if it's an exact fit. I'm looking at mine and it looks like I've got a few more unused pin locations than the diagram you've provided. However, yours is labeled "C101F/M." What does the C101 represent? I may be able to cross-reference this back to what my vehicle uses.
Old Oct 6, 2017 | 10:08 AM
subford's Avatar
subford
C101 stands for Connector Number 101 in Ford Wiring Diagrams.
The C101F stands for Female part of connector C101.
The C101M stands for Male part of connector C101.
Old Oct 6, 2017 | 12:23 PM
Mark Twain's Avatar
Mark Twain
This is great. Thank you. Is the C101 pretty standard in the 93 f-series trucks or is there something I can reference on my truck that would tell me what connector I should be referencing?
Old Oct 6, 2017 | 01:59 PM
subford's Avatar
subford
The Connector number C101 is standard in the 93 f-series trucks but its wiring will differ with engine sizes.
Old Oct 7, 2017 | 08:58 AM
Mark Twain's Avatar
Mark Twain
I took this information and went back to my connector. I found 2 missing wires and 2 wires that were miss matched between the male and female ends.
I'm missing the yellow/green wire receptacle and the yellow/red wire receptacle. Any ideas where these are supposed to come from?
Old Oct 7, 2017 | 09:25 AM
subford's Avatar
subford
The 1993 5.8L engine does not use the yellow/green wire (PS pressure sw) and it does not use the yellow/red wire (knock sensor). They are used on the 5.0L engine only. The pinout was listed in the manual to cover both the 5.0L & 5.8L engines.
Old Oct 7, 2017 | 09:45 AM
Mark Twain's Avatar
Mark Twain
That's reassuring! So it looks like I just need to move some wires around (theoretically) and I'll be doing burnouts in no time. Thanks for all your help and I'll be sure to keep you posted on how the rewiring turns out.
Old Oct 7, 2017 | 12:33 PM
Mark Twain's Avatar
Mark Twain
So the 2 codes fro TPS and EGR below voltage minimum went away. But I got a new one (code 334) for the EGR being above maximum voltage.... 2 steps forward, one step back. Any ideas?
Old Aug 17, 2024 | 08:56 AM
Ray Berglan's Avatar
Ray Berglan
1st Gear
2001 F-150 4.6
I need a wireing schematic that will show me where the fuses in the under the hood fuse box get there power from
Old Aug 18, 2024 | 07:45 AM
subford's Avatar
subford
C175 supplies the power.
nrbacarl
Apr 4, 2016 01:26 PM
Trent Racer
Aug 21, 2015 05:35 PM
ss0345
Apr 21, 2015 04:22 PM
Custom66Cab
Apr 4, 2013 06:38 PM
marine1200
1947 and Older Ford Trucks
Oct 29, 2011 11:40 AM
