What size battery terminal bolt/nut (‘05 Excursion 6.8)
Old Apr 26, 2026 | 01:21 PM
sgc2c's Avatar
sgc2c
See the pictures I attached here.
I lost the nut that held the terminal tight.
I purchased this other one from Walmart and it’s too big.
What is the right size? The new one (the shiny one in the picture) is just slightly too big.
The one I purchased is supposed to be the “Everstart 923-2W Top Post Replacement Bolts and Nuts, Plated Steel“.
Old Apr 26, 2026 | 01:28 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Had to dig through my notes to find it but I usually run M6x1.00
Old Apr 26, 2026 | 02:11 PM
sgc2c's Avatar
sgc2c
Thanks Toreador.
is that smaller than the 923-2W that I bought?
Old Apr 26, 2026 | 04:59 PM
Toreador_Diesel
I don't know but when a come across a customer vehicle where the bolts aren't the correct ones or they're missing, I use a stepped drill bit to fix and enlarge the hole if needed. Then I use a washer (again if needed) so the connection is tight again.
Old Apr 26, 2026 | 07:02 PM
sgc2c's Avatar
sgc2c
Found the right size at Advance Auto.
You were close!: Turned out to be m7
Thanks for pointing me in the right direction.
Old Apr 27, 2026 | 12:40 PM
Toreador_Diesel
You're welcome
mackendw
Jun 12, 2025 02:55 PM
powerscol
Jun 30, 2022 10:42 PM
GGerald
Jul 27, 2018 07:00 PM
Silverhks
May 31, 2018 09:22 AM
andrewzx92000
Nov 8, 2012 01:05 PM
