Parking Aid System Sensor OHM reading
Old Apr 24, 2026 | 10:43 PM
billygoat's Avatar
billygoat
I do not have a code reader to tell me which one or all of my rear back up sensors are working so I am testing the OHMs. Does anyone know what these should read? I have several used ones from the junkyard that are all over the place. I want to purchase OEM, however, these are about $85/ea.
Thank you in advance
Old Apr 25, 2026 | 05:07 AM
01__Excursion's Avatar
01__Excursion
Doesn't look like many resistance values are given. When I added the PAM system to my 01 using new and used parts, I found my PAM plug had corroded pins. Once I found and fixed those I was fine. A bad speaker will prevent the system from working too.
Shop manual procedure below form the 2001 book. Wire colors will be different than your year and possibly pin positions. But the test procedures should be the same.....
Old Apr 25, 2026 | 05:46 AM
Packard42's Avatar
Packard42
Code reader
Seems like a lot of work. Maybe try and see if Autozone or Ford dealer would just read the codes for you? I have a code reader and found one bad backup sensor. Center left.
Gwilkrrs
Jun 17, 2022 08:28 AM
Dave042
1997 - 2003 F150
Jan 19, 2016 09:22 PM
tcjhkbjt
Feb 10, 2014 09:02 AM
live2hunt
1983 - 2012 Ranger & B-Series
Aug 11, 2007 01:37 PM
johnappleseed
Oct 31, 2004 10:22 PM
