Strange thing
Old Apr 24, 2026 | 03:03 PM
Omni43's Avatar
Omni43
Strange thing
After getting my engine and transmission rebuilt, I put my 72 f250 back together and it runs great. However when it is idling if I turn the headlights on the truck will die, or to keep it running I have to give a lot more gas. Has anyone else ever experienced this? I have no idea why that would happen.
Old Apr 24, 2026 | 04:47 PM
davelj's Avatar
davelj
It sounds like a charging system problem. The system should hold 13-13.5 volts at idle with the lights on. It may be dropping so low the ignition can't operate correctly.
Old Apr 24, 2026 | 06:58 PM
Omni43's Avatar
Omni43
Charging is working ok.
Old Apr 24, 2026 | 09:48 PM
blue68f100's Avatar
blue68f100
Do you have the timing set right? Sounds like it's running retarted.
Put a volt meter on the power to the coil and see if the headlights are dropping the coil voltage. If you have an amp meter measure what your head lights are pulling too.
Old Apr 24, 2026 | 09:56 PM
JimsRebel's Avatar
JimsRebel
When it is running at idle, try unplug the sockets on the headlights. See if it dies.
Sometimes the filiments in the headlights proves a ground path, that should be provided by ground wires.
You might be missing needed grounding wires.
Jim
Old Apr 25, 2026 | 12:09 PM
manicmechanic007's Avatar
manicmechanic007
What about the connections and the power coming through to the ignition coil?
I'd check the voltage at the back of the headlamp switch and the coil
Your headlight switch may be shorting out and bringing the system voltage down
I'd also check the voltage at the coil positive terminal to verify what's happening
Old Apr 25, 2026 | 10:22 PM
Omni43's Avatar
Omni43
Thanks for all the great suggestions. I'll try to get on it tomorrow.
Old Apr 26, 2026 | 02:07 PM
Omni43's Avatar
Omni43
So I checked the voltage at the coil and I have 12 volts. I did discover, however, that any time I flip on anything electrical, lights, wipers, radio, flashers; there is a hesitation, or a hiccup with the engine. The more power it draws the bigger the hesitation. And as I said before if I don't rev the engine when I turn on the lights it will die. Any other ideas or theories are welcome.
Old Apr 26, 2026 | 02:54 PM
manicmechanic007
Your 72 has points or Duraspark?
Sounds like something is dragging your electrical syatem down
Could be a short
Could be a bad ground
Voltage drop on a few wires and check every ground and its wire condition
Voltage drop can happen in ground wires too
You can use jumper cables as temporary grounds and test it again
Your coil is staying right at 12v when the dying occurs?
How about the power into the distributor if a Duraspark?
Here is a diagram of a Duraspark from a tester I have 1 of
Old Apr 27, 2026 | 02:39 PM
fe390pc's Avatar
fe390pc
Well, sounds like you have a lot going on.
1) If you have the stock ignition system, (points and condenser) you should only have about 8 Volts at the coil. The power feed should be through a resistor wire. I think you need to see where you are getting your Coil Feed from.
2) What is your idle set to? If its too low that can cause an issue.
Old Apr 29, 2026 | 08:42 AM
Omni43's Avatar
Omni43
Turns out that my alternator was bad. That fixed the problem. It was putting out 13.3 volts but once you put a load on it, it failed. Got it tested at a parts store. Thanks for the comments and suggestions.
Old Apr 29, 2026 | 09:53 AM
fe390pc's Avatar
fe390pc
Awesome news!
WudUpJonathan
Electrical Systems/Wiring
Oct 27, 2024 06:17 PM
EugeneSevier63
May 28, 2024 06:29 AM
bugeye01
Jan 19, 2023 08:58 PM
sigboss
Nov 17, 2001 05:28 PM
