Headlights Kills the Engine
Old Jan 18, 2023 | 10:11 PM
bugeye01's Avatar
bugeye01
This seems strange. 1994 F250, 460, 2WD, automatic. My son's truck. This truck has given us a lot of problems with starting/not starting and charging/not charging. I thought we had them all addressed, but today I had to rescue him again. The entire truck had no electrical power, and the issue was a loose (ie broken) battery ground cable. But after correcting the ground, now then engine starts fine, but when you turn on the headlights it kills the engine. Every time. The running lights and taillights do not kill the engine. Any ideas?
Old Jan 18, 2023 | 10:37 PM
Anonymous12's Avatar
Anonymous12
I doubt it has anything to do with it, but I have some aftermarket KC lights on my truck. The distributor cap was old and the cap caused a no spark condition when the KC lights relay was plugged in. So I replaced the cap and while I was there the rotor and it was fine, it had spark again.
Old Jan 18, 2023 | 10:48 PM
Prototypemech's Avatar
Prototypemech
When a vehicles has a bad large-ground, the starting current tries to find another way to ground and it's through smaller ground wires. Sometimes, it results in the harness burning up and requiring major harness tear down and repair.
But the easiest thing to do is check your existing ground connections and inspect them for tightness and burning. The ones you'll be most interested in are the ground wires near the headlights.
Ground terminal 100 (G100) is common to both your left headlight and your ECU relay. It's located on the backside of your radiator support near the left headlight.
Ground terminal 101 (G101) is common for both your right headlight and one of your ECU sensor grounds. It's located inner right fender, next to your battery. ​​​​​
Old Jan 19, 2023 | 06:35 PM
bugeye01's Avatar
bugeye01
That was it. The grounding system. Why Ford decided to make ground so complicated I don't know, but establishing a really good battery ground to the body, cleaning up and re-establishing both headlight grounds solved the problem, and the headlights are brighter, too. Thanks!
Old Jan 19, 2023 | 08:58 PM
Prototypemech
I was hoping you'd reply back. I'm glad you got it fixed. Happy trails, partner.
whiting5
18
Mar 19, 2023 03:53 PM
PoorOldBlue92
May 13, 2019 08:08 PM
ford f-200
Electrical Systems/Wiring
Jan 20, 2009 04:46 PM
RobBroekhuis
May 18, 2005 04:49 PM
jberylecrider
Jul 22, 2002 11:07 AM
