Gas syphon in back out/ fuel pump?
Old Apr 20, 2026 | 04:38 PM
jzjames's Avatar
jzjames
‘syphoning’ !
On my 4.9 Inline Six I have a Motorcraft 2bbl carb.
Every time I have to start the truck for the first time of the day, it cranks for a long time. 15 - 20 seconds, before the carb gets gas and starts. Anybody else experienced this?
It’s done this for the 25 years I’ve owned this truck. It seems like the gas is siphoning back out of the carb on shutdown. And the fuel pump needs to pump until it fills the bowl back up.
Would like to solve this problem, I don’t think it’s an ignition or engine problem.
Would low compression cause this? It is a very high mileage engine and probably has considerable blow by.
Old Apr 21, 2026 | 10:12 AM
manicmechanic007's Avatar
manicmechanic007
More likely it is "boiling" or "percolating" out
Not a whole lot you can do about that
It might have a leak in the power piston allowing all the fuel to drain into the intake where it also evaporates out
If you have not overhauled that 1bbl carter Motorcraft carb, I'd start right there
The main power piston in those carbs controls the metering rod traveling into the jet, and also is the accelerator pump
You'd be surprised how well they run with a new diaphragm in them
Old Apr 21, 2026 | 11:58 AM
jzjames's Avatar
jzjames
It’s a 300 I6. With the Offenhauser intake and a Ford 2bbl carb.
‘Runs great but won’t start until the fuel is pumped back up into the carb - every time when cold.
Now I’m wondering if the low compression engine is causing this because when engine is cold the compression would be the lowest, I.e. longer cranking to get it to fire.
‘Starts on first click when hot. IDK.
Old Apr 21, 2026 | 12:25 PM
blue68f100's Avatar
blue68f100
Manual choke or electric? Low compression will not effect how long it takes to get fuel. That is based on the output of the fuel pump. May want to try a thermal insulator under the carb to minimize the boiling of the fuel. You could add an electric fuel pump, then it would only be a few seconds before the bowl is full.
Old Apr 21, 2026 | 01:46 PM
manicmechanic007
The 2bbl has a leaking power valve ?
I believe that can drain a 2bbl Motorcraft
They also might have well plugs that can leak
It's been a while since I've looked at one
It still could be percolating or evaporating out
Old Apr 21, 2026 | 01:48 PM
manicmechanic007
I'm with your first observation, in that it is fuel taking time to reach the bowl
See if it fires right up on ether, cold
Old Apr 21, 2026 | 03:36 PM
WDXPW's Avatar
WDXPW
Try a phenolic spacer it stopped my fuel percolation mine was enough to do what your explaining.
Old Apr 22, 2026 | 01:37 PM
jzjames's Avatar
jzjames
’See if it fires right up on ether, cold’
I am going to try this. I dont think I have a boiling fuel situation with this carb, But I could be wrong.
All this long cranking every day has me worried what it’s doing to my ring gear! I keep trying to figure this out.
Wouldnt a low-compression condition take more cranking when cold ? Fires right up on restart.
(No choke on this carb! I put a manual choke on it at one point and it made no difference. Pump pump pump. Crank crank crank.)
Old Apr 22, 2026 | 01:45 PM
manicmechanic007
Yes
What is the compression reading?
Hot restart or cold restart, the compression readings should be the same
How long have you had it running with the Offy intake and 2BBL on it?
Long enough to get the rings broken in, right?
I would assume the engine is fine until you check the compression if it starts and runs
you could check the "wet" compression
We used to fire engines up, that have sat for a long time, on trans fluid and ether or gasoline down the horn
Those had low compression until the rings got seated
6sp33d
30
Jun 6, 2026 08:43 PM
djtexcarr
17
Nov 25, 2025 06:27 PM
79outlawf150
May 29, 2010 09:14 PM
jpmiller
Oct 14, 2004 05:26 PM
meangenejr
Jul 27, 2004 07:52 AM
